Old 01-04-2006, 05:22 PM
1FASTws6 1FASTws6 is offline
Camshafts???
Who make the best cams for the 98-02 LS1 trans am's. How much will they set me back with installation, and will i feel a differance??? THANKS
Old 01-04-2006, 06:22 PM
CreepingDeath94 CreepingDeath94 is offline
I'm not sure what they run on the LS1's, but a camshaft is one of the biggest things you can do to help the engine breath...If you do it right you'll feel the difference.
Old 01-04-2006, 09:55 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Camshafts???
Do you have ALL the bolt-ons yet??
If not...cam isn't worth it.
Once the car has the bolt-ons though, a cam can get you 60 RWHP with a good tune.
I installed mine....$1000. With install....probably $1500.
I can't tell you what cam would be good for your car.
Are you looking for power down low?
Power up top?
Good idle?
Do you have to pass emissions?
M6 or A4?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 01-05-2006, 03:55 PM
Re: Re: Camshafts???
A good one. Something between the 4-$500 range. 600 MAX. i want all round power but dont want it to cluttery. What bolt ons do i need. I have the LS6 intake,lid,getting the stroker ported. 1 more question Luos... how can u tell the differance between the ls1 and ls6 intake, and ported TB.
Old 01-05-2006, 04:06 PM
Mr. Luos's Avatar
Firebird Guy
Re: Camshafts???
Ported throttle body will be shiny inside. Like it has been polished...because it has.
LS6 intake and LS1 intake.....little harder.
Easiest way I can think of quickly is the EGR port. LS1 has it, LS6 doesn't. It is a location for a hose right above the throttle body.
The cam itself should cost NO MORE than $400.
Then add valvesprings ($250 with retainers), pushrods ($120), oil pump ($140 if car is high mileage), LS2 timing chain ($40).
Add install price.
In order for a cam to breathe well, you want full exhaust, including headers. LS6 intake normally does well enough on stock heads with a cam.
There are TONS of LSx cams out there. It depends on how you want it to act.
Stock'ish'
Old 01-05-2006, 04:09 PM
Darrensls1 Darrensls1 is offline
Re: Re: Re: Camshafts???
You basiclly need exhaust since you all ready have a lid. 98-00 LS1's had the ls1 intake manifold and 01 & 02 had the LS6 intakes.
You'll want a catback (or cutout) and LT headers. You can get an ORY pipe if a visual emission test is not a concern or you can get a HF catted Y-pipe if it is an issue. Once exhuast is done then the next question is are you an automatic? If so matching a torque converter, gears and cam would be most benificial. If it's an M6 then you just need to pick a cam.
Emission wise, the most popular cam that can pass with a good tune is a 224/224 on 114 LSA. Good mid range power, very street friendly and it can pass emissions.
If emissions are not an issue then you can start looking at slightly bigger cams. One of my favorite vendors for cams is Futural. Check out this website and look at all these cam specs. FM13 is an extremly popular cam these days.
http://www.futralmotorsports.com/fms....asp?pf=1&pg=5
If you have any questions you should give those guys a call. They are cam gurus and will lead you in the right direction.
1999 Pontiac Firebird Formula 100% bone stock. No really it is
Old 01-05-2006, 04:25 PM
Mr. Luos's Avatar
Firebird Guy
Re: Camshafts???
Futral is a great choice.
Along with Thunder, Texas Speed, and a couple others.
Stock'ish'
Old 01-05-2006, 07:44 PM
Thanks guys. I have 1 MORE QUICK QUESTION. When i told this kid i have and ls6 intake, lid, programer, TB, catback, he says i only have 320 or 325hp. I think he means rear wheel HP not crank. What are your suggestions. And wut should i tell him at school tommorow???
Old 01-05-2006, 07:47 PM
Mr. Luos's Avatar
Firebird Guy
Re: Camshafts???
That should be RWHP.
What the hell does he mean 'only'??
Stock'ish'
Old 01-06-2006, 08:57 PM
im pretty sure he means 320-325 rear wheel horsepower. I know im not sending 320 to the flywheel with those bolt ons. This kid has 360 to the wheels that goes to my school, 01 ws6
Old 01-06-2006, 08:58 PM
Mr. Luos's Avatar
Firebird Guy
Re: Camshafts???
360 to the wheels??
What mods?
Stock'ish'
Old 01-07-2006, 08:56 AM
lid, TB ported and polished, ls6 intake, kooks LT's, loudmouth, programer, and cams. i THINK thats all.
Old 01-07-2006, 09:04 AM
Mr. Luos's Avatar
Firebird Guy
Re: Camshafts???
Must be a small cam.
Stock'ish'
Old 01-07-2006, 10:58 AM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Add install price.
Unless he is an M6 and went 3~>2 racing....I wouldn't bother with pushrods. I do agree with oil pump on a higher mileage car. Timing chain on a higher mileage car too. New/stiffer valvesprings with retainers are definately needed with the cam.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
