Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-04-2006, 04:08 PM
razz9818 razz9818 is offline
gsr tanny on a rs
broke but still dreaming...damn!!!
anyway my tranny's been acting up for a couple months now, the
syncros are f**ked up 3rd gear forget about it! so i was pondering
when i can afford it, should i slap on a gsr tranny so i can get some
more POWER well it make a differance? i know ill b revving bit higher
but thats all my search answered .....now that iam dreaming a gsr head
would be nice as well!!! THANX GOD OR WHOEVERELSE IS LISTENING!!
it hurts to see your baby in pain and you cant do anything about it cuz your broke!!
Old 01-04-2006, 04:50 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: gsr tanny on a rs
No, you won't be reving higher. How high you rev depends on the engine and ECU, not the transmission. All you will gain is faster acceleration. You'll have the same power, you'll just get it faster.
Old 01-04-2006, 05:30 PM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
At any given speed, the rpms will be higher with a gsr tranny because the gears are closer...
Old 01-04-2006, 06:06 PM
CivicSpoon's Avatar
There is no Spoon
Ohhhh, sorry I read that wrong. I thought he ment that he would be able to rev higher.
Old 01-05-2006, 02:36 PM
Re: Re: gsr tanny on a rs
thanks guys!! wondering if i change my ecu and tranny how can i revv higher then stock w/out f**ken up my engine will stage two cams help me any?? thank for the help i think gsr tranny it is
Old 01-05-2006, 02:45 PM
CivicSpoon's Avatar
There is no Spoon
Just because you make it rev higher, doesn't mean it will make power any higher. Though with upgraded cams (and valvetrain), you will probably be able to rev a little bit higher (my guess is maybe a few hundred rpms max).
Old 01-05-2006, 06:54 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
a LS motor peaks hp out at 6300rpm i believe so why do you want to rev higher anyway...higher compression is the answer if you do want to rev higher but the cams will also help...if you want more acceleration than get a b16 tranny instead of a gsr...
Old 01-06-2006, 02:56 PM
thanks again !! if i slap a b16 tranny i will b revving way hi on the highway thats the only reason i want a gsr.besides its a daily driver and i drive the highway a bunch. so is that a good reason not to get a b16??
basically i dont want vtec sound like a headache to maintaine .but i want some noticable gains so I would have to look into a itr ecu, valva's, and cams i already own skunk 2 cam gears and a dc fuil rail so i kinda want to use these parts. thanks in advance for your suggestions
Old 01-07-2006, 11:11 PM
K2sInteg98 K2sInteg98 is offline
well since you do a lot of highway driving, you will be revving at 4k and it will be loud and annoying. The gsr tranny will still stay at a higher rpm when crusing but not as bad as the b16 or itr tranny. If it is your daily driver but you want a little pickup, a gsr tranny will definately help. It will improve your 1/4 mile times because youll have faster acceleration because the gears are closer. Also, dont worry about trying to revv high. To revv high and actually make power, youll need a lot more then just a ecu and cams, and your dreaming enough already so stop while your ahead. Cams can make you revv a little higher but you might need a new valvetrain, and to make use of its power, your gonna have to get it tuned. For now stick with the gsr tranny and let us know when u get that so we can help you later.
