Old 01-04-2006, 01:16 PM
Billnmd2005 Billnmd2005 is offline
94 LeSabre
My dash ABS brake light has been on ever since I got this car.Is the sensor bad? if so how do you fix it??
Also my interior lights work but after a while the fuse burns out.Everytime I put a fuse in the fuse burns out. I tried a bigger fuse it lasted about a week that also burnt out. What is the problem?? Is it a short ? If so is it easily found and fixed?
Any help would be welcome.
Thanks Bill
Old 02-10-2006, 01:45 PM
Bassasasin Bassasasin is offline
Re: 94 LeSabre
Need to use a current tracer specialty tool.. sorry..
Old 02-10-2006, 04:25 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 LeSabre
On the abs you need to have it scanned on a abs function scanner for codes and comparative wheel speeds.
Old 02-10-2006, 05:50 PM
stuzman stuzman is offline
Re: 94 LeSabre
Thanks Bill
For the ABS, as max said, get it scanned with an ABS capable scanner. As far as the fuse blowing, it sounds like you have a partial short somewhere in your circuit. I wouldn't put a bigger fuse as that could lead to a fire. The partial short could be anywhere that the fuse feeds. So, this one could be very time consuming to find especially if it turns out to be somewhere up in your dash.
Old 02-13-2006, 09:49 AM
rustbucket rustbucket is offline
Re: 94 LeSabre
Do you use automatic door locks? I had a driver one that blew the door lock fuse. I dont know it the interior lights are on the same fuse.
Daily Driver: 2008 Chevy Impala - 30000 mi
Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre
