Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-03-2006, 11:17 PM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
Starting Problem :( ideas?
Ok so when I turn the key to start my car, nothing happens. Actually, i hear a slight whine for a few seconds (not sure whether that is the fuel pump or the starter solenoid) but then nothing happens. About 10 seconds later the car will start. It isnt a sluggish start either, the battery seems fine (headlights are not dim, and clean connections on battery). Any ideas as to what this is?
Probably starter related, but any confirmations would be appreciated.
Old 01-03-2006, 11:59 PM
WReX WReX is offline
Re: Starting Problem :( ideas?
does it crank for those 10 seconds its not turning over? is it cold where you are?
might be a spark plug/distributor issue, possibly a bad/going bad battery?
and i believe that noise your hearing is the fuel pump relay under the hood
26 PSI anyone?
Old 01-04-2006, 12:11 AM
Banned
The engine does not crank at all during those 10 seconds. When it finally does turn over, it turns over strong and starts right away. I would like to think it is not my plugs or distributor because all of that was replaced less than 10K miles ago. It is not too cold where i live, but the battery in the car is definitely not anywhere near being new lol. Seems to have juice still...
Old 01-04-2006, 12:17 AM
i would try and hook your car up to another car with jumper cables and start it as if you were getting a jump and see if anything changes (preferably someone with a newer car or battery)
just an idea
26 PSI anyone?
Old 01-04-2006, 12:36 AM
Banned
Not too bad of an idea, I'm gonna try that tomorrow. If its not the batter though, think it could be the starter solenoid or even just the starter itself? I did start my car without having that ground wire from the valve cover to the frame connected one time, i doubt that is of any relevance though. but it started this problem after that.
Old 01-05-2006, 12:17 AM
that may have something to do with this but if its connected now and problem persists then i would think it safe to say that its unrelated
if it is your starter assembly, i would suggest just replacing the whole thing, its more money but also more security on your cars life
but anyway, good luck with the issue
26 PSI anyone?
