| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
i have changed the Map sensor, TPS sensor and set it to 0.99V as stated in my book, Fuel vapor purge valve, Idle position sensor, EGR valve, EGR solinoid, PCV valve, O2 sensor. i also checked for vaccum leaks over and over again, and cleaned the throttle body with "seafoam". I also bought a code scanner and it only pulls a system pass code (111). I can not figure out what causes the rough, and high idle problems. The truck idles at about 1500 rpm but is very rough, however when your actually driving it runs perfect with no hesitation or lack of power. Any comments you think might help would be appericated.
Re: 1992 F-150 5.8l 351W Rough idle wont go away plz help!!!!!!!!!!!
The only things i can think of off hand are the plugs, wires, dirty injectors, MAP sensor or PCV Valve..
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
Later Ed . |
i have an 87 ford f-150 with the same problem turns out i had an burned vavle not reall bad but enough to make it idle rough
Yeah, i forgot to mention burnt exhaust valves are sorta common on these engines.
my 01 f150 idles rough enough you can feel the floor shake at times but runs perf also. Went to ford they told me thats just ford i was pissed. If i rev it about 1500 rpm is the worst miss of all but floor it driving doesnt miss at all
sounds like a manifold vacuum leak, have you changed the valve cover gaskets?
