Old 01-03-2006, 08:25 PM
Matthew196 Matthew196 is offline
Exclamation Temperature Gauge Problem 92 S-10 Blazer
Whe I start the vehicle COLD the temperature gauge alway going right to MAX every time I start it!! If I shut it off and start it the next day it still does the same thing...
Any suggestions?? We have recently replaced the Coolent Senor in it but this still bothers....
Any suggestions appreciated. Also i do not own a scan tool either.
But it not giving any codes either when you short A snd B in the diagnostic terminal.
Old 01-03-2006, 08:48 PM
Floyd_ODB Floyd_ODB is offline
Re: Temperature Gauge Problem 92 S-10 Blazer
It sound like the sending unit circuit has an open(diconnected?) The sensor and the sender are different. the sensor(usually 2 wire) is for the ecm(codes etc.) the sender (usually 1 [green] wire) is for your guage
Old 01-03-2006, 09:03 PM
Well that sounds like a good reason, as the vehicle dont act any different with that being on MAX. So got to be the computer is reading the temp ok. As I hear the Coolant Temperature Sensor plays a MAJOR part in how the vehicle runs!!
But it does make the Check gauges light stay on, now is that operated off the computer or directly off the temp guage???
Old 01-03-2006, 09:15 PM
I dont know if its part of the "ECM" but something is prbly monitering your guages for you. Alot of people dont watch thier guages so this is a system to help ensure engine life lol.
Old 01-04-2006, 06:56 AM
Re: Re: Temperature Gauge Problem 92 S-10 Blazer
Ok i will try your options and get back to you when I get a chance to check this out about that (green) wire!!
Thanks for the info however!!
Old 01-04-2006, 11:44 AM
blazerfromhell blazerfromhell is offline
Did you replace the Coolant Temp Sensor? I just had problems with mine acting crazy ( Needle jumped all over the place) Replaced the sensor ( drivers side of car) and all is well again.
Old 01-04-2006, 08:37 PM
Well I did replace the sensor before and it corrected it for a little while, but it then started acting up again. plus now it stays on MAX all the time and I cannot get it to go off the MAX Mark...
Old 01-05-2006, 09:54 PM
Re: Re: Re: Temperature Gauge Problem 92 S-10 Blazer
Did you take a close look at the connector? mine was really dirty and Oxidized. Take a look with a bright flashlight, maybe it could be doing it.
