Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '93 - '96
Old 01-03-2006, 08:12 PM
THSautostudent THSautostudent is offline
94 Passat Wagon V6 won't start
I have a 1994 Passat GLX Wagon that will not start. There is no fuel getting to the fuel rails so I figured that it was the fuel pump. However, the main fuel pump is not getting any voltage. I have not checked the fuel pump relay (by the way, where is it?), but did replace the fuel pump fuse with no consequence. I have not checked the voltage across the fuel pump fuse. Also if anyone has a clue what service manual to use for it, please tell me.
Old 01-03-2006, 08:32 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 94 Passat Wagon V6 won't start
i believe the fuel pump relay is # 52. right above the fuse pannel in car there a common problem
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 07-10-2009, 02:43 PM
lithuanian2 lithuanian2 is offline
i had a same problem my computer ecu was bad !! i have 1994 vr6 for parts if u need 5 spd manual
