Old 01-03-2006, 05:54 PM
laxman21's Avatar
laxman21 laxman21 is offline
Rear wiper trouble.
Yes I did a search.
Mine works half of the time. The first stroke works fine back and forth. On the next one, the first stroke is fine, the back stroke is weak. Sometimes it is just jerky or doesn't work at all.
Switch problem?
99 blazer
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 01-03-2006, 08:08 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Rear wiper trouble.
Mine did that. You can try replacing the circuit breaker for it and see if that makes a difference..And putting on a new blade.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 01-03-2006, 09:24 PM
laxman21's Avatar
Re: Re: Rear wiper trouble.
Did that work for you?
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 01-03-2006, 09:43 PM
billibong's Avatar
billibong billibong is offline
Might be a gear beginning to wear out in the actual rear wiper assembly. That is what happened to mine. You can notice it if it starts to make a clicking noise and gives you trouble with movement.
A replacement motor and arm is usually between $50-75 at a parts yard. It is a fairly easy replacement.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 01-03-2006, 09:45 PM
Yeah. The circuit breaker was weak.
Old 01-03-2006, 10:18 PM
DaveLance's Avatar
DaveLance DaveLance is offline
It might just need to be lubricated. If you hold the blade off of the window, does it go through the normal wiping motion?
