Old 01-03-2006, 05:11 PM
JoeNezz JoeNezz is offline
91 PA idles rough
Hello
I have a 1991 PA/ultra & it just started idling rough today & is slow to accelerte.
I have just changed the plugs & wires.
when I changed the wires there was rust in two of the boots when I pulled the ends off the coil pack so I cleaned the terminals good before I put the new wires on but it made little difference in solving the problem.
I checked for trouble codes but none were stored & no SES light has ever come on while driving or at idle.
Does anyone have any ideas as to what might be causing this?
Thanks in advance, Roger
Old 01-03-2006, 06:16 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 91 PA idles rough
Have you changed the fuel filter? How many miles on the car?
Old 01-04-2006, 12:32 AM
crys36 crys36 is offline
Send a message via AIM to crys36
Could be the coil pack and module, happened to me.Changed plugs and wires still Ran like crap til it just died 1 day , also make sure your wires are all on the plugs their suppose to be. Its easy to have 2 wires you thought were on the right cylinders until you checked it the 5th time.-Chris
Old 01-04-2006, 08:10 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
In addition to what crys36 and hotz28 said, also check your PCV valve and lines.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-04-2006, 11:29 PM
mikelund mikelund is offline
It's a '91. In addition to all of the above, I have changed all the rubber vacuum hoses and connectors on mine. Seems like some elements of the engine systems run better on the correct vacuum pressures. I also replaced the positive cable, not just cleaning, made a substantive difference.
