Old 01-03-2006, 03:54 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Why would the passenger-side lock stop working after the window broke???
If ya'll didnt know already, my passenger side window broke. I just noticed this, but, the passenger side lock does not work, (I am not talking about the power switch button but the actual lever that you push to lock the door)...When I try to lock the lever shut it seems to close only halfway and the door does not lock, it can still be opened. This happened as soon as the window broke...Do you think that maybe a shard of glass is blocking the mechanism? Or maybe the window must be in place for the lock to work? Any help will be great!
THANKS!
Old 01-03-2006, 06:17 PM
2006 ECLIPSE GT 2006 ECLIPSE GT is offline
Re: Why would the passenger-side lock stop working after the window broke???
the samething happend when someone broke into my lancer. when they replace my pass window, the next day i notice my door wouldn't lock. take the door pannel off and make sure the metal line from the switch to the to the lock is stiff. cuz if its out of place, the switch wont close all the way and line is to loose to push the lock close. there should be a little clip or something to hold the metal line tight inplace.
i hope this helps
Silver 2006 Eclipse GT
came with factory body kit, everything else is stock.
Green 1996 Eclipse GS (my first baby)
Greddy headers and catback, Injen intake, MSD ingnition coil, MSD 8.5 wires, OBX crank pulley, short shifter, Blitz body kit, 18" rims, projector headlights, halo reverse gauges, and some kind of racing seats.
Gray 2004 Lancer Ralliart
Bone stock
Black 1997 Eclipse GST
SOLD
Old 01-03-2006, 07:57 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
The window probably fell on the lock and knocked something loose, check the lock like mentioned in the last post.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 01-03-2006, 08:13 PM
Bhanks for the help but, the metal line is real stiff. Even when I grab the line and pusk it in, it will only go like half way...it is like there is something blocking the meachanism or something.
Any other help is great!
THANKS!
Old 01-03-2006, 08:14 PM
Thanks for the help but, the metal line is real stiff. Even when I grab the line and push it in, it will only go like half way...it is like there is something blocking the mechanism or something.
THANKS!
Old 01-04-2006, 05:15 PM
Well, thanks to the enormous amount of replies I received, a whole 2 answers, j/k, I fixed the problem...
Its like I thought, there where 3 pieces of glass blocking up the mechanism. All I did was dissemble the lock from the door, remove the glass rail, unhook, the wire harness clip, and just shake the glass loose. (Just for future reference)!!
