Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-03-2006, 03:34 PM
rx7bsebal2oo6 rx7bsebal2oo6 is offline
Dying
When I first start my car it takes it a second to idle and then will just drop down to 0 and the car will shake and almost shut off...Then if I touch the gas it will go back up but then right back down and sometimes shut off...After I drive it for a while it's not that bad but it has died when I was sitting at a stop sign.. Do I need to set my idle higher? Or can it be a bad alternator?
Old 01-03-2006, 04:17 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: Dying
have you made any modifications to the car lately?
Old 01-03-2006, 04:59 PM
Red Hot Mitsubishi Red Hot Mitsubishi is offline
Re: Dying
I am having the same problem , so please help us!!!
Old 01-03-2006, 07:01 PM
Re: Dying
car is completely stock
Old 01-03-2006, 07:59 PM
Re: Dying
try resetting your ecu by unhooking the battery for about 15 mins. then crank the car, and let it idle for about 10 mins. see if that fixes the problem
Old 01-06-2006, 05:17 PM
Re: Dying
i went to advanced auto.. they said it had to do something with my fuel something.. that its clogged
Old 01-06-2006, 11:36 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Dying
huh
how many miles on your car?
Don't act like you don't love it.
503/2000
Old 01-07-2006, 12:51 AM
Re: Re: Dying
ehh....we need a better description than that.
do this, go back to autozone, get you SES light scanned, get the code and post it here.
Old 01-07-2006, 08:33 AM
cficare68's Avatar
cficare68 cficare68 is offline
Re: Dying
I'm going to go out on a limb here and say that it is probably his fuel pump. My girlfriends old Contour would pretty much the extact samething that yours is and that is what it was.
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 01-07-2006, 10:55 PM
rcdwvd rcdwvd is offline
Re: Dying
How long has this been going on? Sounds like your battery or alternator.
If you're just doing city driving, run it on the highway a bit to charge the battery and see if that does the trick.
Old 01-08-2006, 02:57 AM
SLoe's Avatar
SLoe SLoe is offline
Vacuum leaks can also cause idle problems.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 01-08-2006, 03:58 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Re: Dying
That isnt going to do anything...unless you never get your car above 2k rpm in the city. Now, your battery might be going bad, in which case you might need to replace that...but even then...once the car is running, most of the work is done by the alternator...so, if the car is on, and then stalls I doubt its your battery.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-08-2006, 03:57 PM
Re: Re: Re: Dying
Wrong. The city has stop lights and stop signs. Best to check for the cheapest solution first, which is an uncharged battery. Then look to things like a bad battery/alternator or a clogged fuel injector.
Old 01-08-2006, 07:01 PM
rodbls's Avatar
Well if you are set on thinking its a battery issue...why go through the trouble of actually driving the car. Hook it up to a charger overnight...and then the next day start it and idle high for like 5 min. Dont waste time driving it places you dont have 2.
Old 01-09-2006, 02:47 AM
Sleepr awd's Avatar
Re: Dying
ok, so if you want to kno if it is a battery problem or alternator problem your local o'reilly or autozone should have a tester they will test it for you for free, going to a mechanic to have that tested would work but its $$$ expensive
driving on the highway does help the alternator out more, just as long as the engine isn't at idle it'll charge more, but if the alternator is going going gone, it really won't matter
it IS possible to overcharge a battery, my friend did it on his CRX and it was a nearly brand new battery and we had ruined it doing so, we only had it charging for an hour while periodically trying to start it
and let us kno whenever you figure it out!
503/2000
