Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 01-03-2006, 01:31 PM
princess_sunfire princess_sunfire is offline
Question '96 sunfire Daytime running lights help
My daytime running lights have recently started to flash (like a stobe light) and won't stay on. I am wondering what this could be and if anyone else has had problems with their daytime running lights. When i put on my head lights it is fine. I have also ruled out the altenator.
Old 01-06-2006, 06:34 AM
They aren't working anymore
Well just an update my lights aren't working anymore. I really want to fix them and am just wondering if anyone has had the same problem
Old 01-06-2006, 10:02 AM
TheGuyz TheGuyz is offline
Re: '96 sunfire Daytime running lights help
ARe you referring to the headlighst blinking or the indicator in dash that wher strobbing?
Since no longer works do your low/high beams work?
I'd check fuse if both are gone.
As well may have a short in wire or wire broken.
Old 01-06-2006, 01:09 PM
homerr homerr is offline
I had the same problem and all it was is a one high beam did not work. Replaced the bulb and OK now.
Homerr
Old 01-12-2006, 09:39 PM
It is just my Day time driving lights that are strobing.
Old 01-13-2006, 12:27 AM
Check the relay, middle front bumper infront of radiator.
Old 01-15-2006, 10:57 AM
Mine staretd doing this, and all i have is low lights, no high beams.
I am going to replace bulbs( with old ones i replaced) and see if fixes, then try relay in bumper, don't really want to play with wiring as all muddy and icey in this season.
Old 01-16-2006, 03:50 PM
I just replaced relay today, and get following symptoms:
start vehicle daylights indicator on, put on low beams, low beams work, put on high beams nothing, then back to low or off and on.
I switched the bulbs and same issue.
Although if i switch to old relaay it flashes indicator, so issue must be a few things.
ANy suggestions other then testing wires?
