Old 01-03-2006, 01:08 PM
WasteGas's Avatar
WasteGas WasteGas is offline
Angry Aw Crap!
Duplicolor badly crazed my C6 shell. After priming it, it looked there was some crazing so I sanded it and was able to smooth it out. Did another coat of primer just for good measure. I went and laid down a mist coat of black waited couple hours then did another mist coat. At the end of the day I went and did the first wet coat and viola the swirly craze!
I did a lot of sanding yesterday to smooth it out as much as I can. I'll lay down Tamiya over it instead this time. I hope there won't be any reaction between the two.
The embossed flags on the front and the back and the engraved corvette in the back is pretty much gone
Oh well... I was thinking of getting another one at Walmart.
Old 01-03-2006, 05:03 PM
cinqster's Avatar
cinqster cinqster is offline
Re: Aw Crap!
Wastegas, I know b*gger all about this kit, but I'm sure I've read somewere that many people have had paint reaction issues with the yellow plastic that Revell used for it.
Old 01-03-2006, 05:36 PM
freakray freakray is offline
AF Modelrater
Re: Aw Crap!
There is a major is a major issue with the latest batch of kits from Revell regarding the plastic type, a quick forum search would hopefully turn something up.
As is mentioned, there are paint reactivity issues which are rather a large concern for those of us that build Revell/Monogram subjects.
Instead of buying a new kit, call Revell on their toll free number and voice your issue with the kit.
Old 01-03-2006, 07:13 PM
cinqster's Avatar
Re: Re: Aw Crap!
Doh...it's just dawned on me that the latest batch of the Revell 1/8th Deuce I'm about to start is also yellow plastic, it's about the same colour as the C6's I've seen at Le Mans - I hope this doesn't suffer from the same issues as this thing is going to eat up body prep time and materials...grrrr!
Old 01-03-2006, 07:15 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Aw Crap!
weird, i've heard all this talk about ti crazing the plastic but I've used duplicolor on a new hummer, mustang and C6 with no problems, it was red filler primer.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 01-03-2006, 07:34 PM
WasteGas's Avatar
Re: Re: Aw Crap!
I used the white sandable primer on mine. Maybe I should've used gray so I could distinguish areas that was actually covered with primer since the mold was white.
Old 01-03-2006, 07:51 PM
digitalbanzai's Avatar
digitalbanzai digitalbanzai is offline
Re: Aw Crap!
Well, i'm calling it, three times i've tried to use Duplicolor black over primer, and it always screws up on me.
Old 01-03-2006, 08:10 PM
blubaja's Avatar
blubaja blubaja is offline
Re: Aw Crap!
Revell's new plastic sucks. Hehe..you censored bugger. Hehe...Is that as bad as F**k to you guys?
Old 01-03-2006, 08:44 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
Re: Aw Crap!
Duplicolor white primer has crazed every styrene kit that I've used it on. It works great on polyurethane.
