Old 01-03-2006, 12:13 PM
hsmda hsmda is offline
4.3 to Boat
I have a 4.3 TBI from a 93 S10 and a ECM from a 91. I want to put it in a boat. What is the minimum I will need to hook up to the ECM to run it? How can I get a map of the connector pins on the ECM so I will know what to connect to which pin?
Old 01-03-2006, 12:37 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: 4.3 to Boat
do you have access to either one of the trucks for a wiring harness? get that and it will go alot simpler. do you have the whole engine(including sensors and wiring)?
what do you have in the boat now?
Old 01-03-2006, 01:21 PM
Re: Re: 4.3 to Boat
I do not have either vehicle. When I know what I'll need, I plan to go to a junk yard and get some wiring components (terminals) and any other sensors needed.
I have the engine, intake with TBI and throttle position sensor, distributor, coil, EGR, exhaust manifolds, water pump and fan.
The boat is a 1962 Glastron with a 4 cylinder Mercruiser I/O.
Old 01-03-2006, 05:42 PM
Floyd_ODB Floyd_ODB is offline
Re: 4.3 to Boat
brass or stainless core plugs!!
Old 01-04-2006, 08:54 AM
Re: Re: 4.3 to Boat
Actually, I plan to make this an onboard cooling system, with a radiator. I don't even want to use overboard water for exhaust manifold cooling.
Old 01-05-2006, 02:50 AM
pipelinerr pipelinerr is offline
Send a message via AIM to pipelinerr
motor will always run in open loop as you wont have speed sensor
Old 01-05-2006, 08:42 AM
Re: 4.3 to Boat
What does that mean, open loop? Won't it look at the oxygen sensor and the throttle position sensor and control mixture from those?
Old 01-05-2006, 01:18 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: 4.3 to Boat
Do they make water jacket headers for a 4.3?
Old 01-05-2006, 05:27 PM
Re: Re: 4.3 to Boat
Yes, but I'm not going to go that route. I'm going to do a dry exhaust, with good insulation and air circulation across the manifolds. I do not want to use overboard water for anything.
Old 01-05-2006, 10:03 PM
16th hippy 16th hippy is offline
Re: 4.3 to Boat
if i'm not mistaken, the 4.3 in particular reads the o2's, coolant temp, intake air and so on for transition from open loop to closed loop. as for wiring diagrams and pin-outs for the ecm, might have to get the factory service manual for that year....or if you know someone with a subsrciption to alldata or mitchell on demand and so on. Best of luck with that transfer, sounds as if it will be a screamer.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-06-2006, 12:40 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: 4.3 to Boat
no speed sencer means his abs wont work, but i dont think thats a real big concern, and get the wiring harness, making your own, will cause a lot of problems
Old 01-08-2006, 08:55 AM
Re: 4.3 to Boat
ABS on a boat....hmmmm, ok, i'll try that out...lol.
Old 01-09-2006, 01:13 PM
Re: 4.3 to Boat
thought you would like that one
