| General Discuss anything having to do with Toyota Supra here. |
boost vs. octane rating
whats the theoretical boost number you can run at 8.5:1on 91 octane pump gas? and does anyone know where i can find an octane vs. boost chart?
Re: boost vs. octane rating
There is no such thing. Each motor is a little different. Boost level and octane ratings aren't the only factors involved in detonation. Ignition timing, intake temps, combustion chamber temps, compressor efficiency, inter cooler efficiency, and plug type are some of the things that play a part. The way to find out how much you can get out of pump gas is to strap your car to a dyno and tune it.
oh. well... i understand most of that, but how does ignition timing and compressor effeciency affect detonation? and doesnt air/fuel ratio affect detonation too?
ignition timeing tells when to spark if its too early or too late the motor will not run right and get bad milage. yes air/fuel mixtire makes a diffrence too.
Tons of things affect detonation.
compression ratio A/F ratio Spark-plug temps intake charge temp timing Pre-detonation is what you are trying to aviod. This is what kills motors, because the fuel explodes as the piston is still traveling towards the head. So you reduce compression ratio richen A/F retard timing cool the intake charge run cooler plugs. On a MKIV turbo, 93 Octane is good to about 16psi (some will aurgue 18PSI) 104 race unleaded race gas is good to 23psi 50/50 mix 92, and C16 race fuel 26psi C16 35+ PSI
94 Supra Turbo 6spd Ported head w/ 1mm over sized valves 6pt cage w/ removable door bars SP67 Single Turbo .81 A/R RPS Manifold SP fuel sys w/ 1000cc injectors, SP rail, & Dual Walboro pumps Aeromotive FP regulator Greddy 3 Row front mount Tail BOV TRD Rear Diff TRD dual disk clutch HKS Racing Wastegate HKS DLI HKS VPC HKS BCC HKS EBC FJO Wideband o2 Greddy Electronic Boost, EGT, Fuel pressure w/ Peak & hold 98 tail and headlights Wings West lip |
