Old 01-03-2006, 07:57 AM
psieater psieater is offline
catalytic converter
My converter is shot, anyone know if you can cut it out and replace it with a straight pipe, disconnected the sensor behind the converter a few days ago with no ill effect, so I don't see the point to replacing the converter?
Old 01-03-2006, 08:23 AM
93LT 93LT is offline
Re: catalytic converter
Legally, no.
Rod
1995 K1500 Ext. Cab Stepside
1997 Olds Bravada AWD
2001 Silverado LT 2500HD CC 4WD
2001 Yukon SLT 4WD
Old 01-03-2006, 08:27 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
You can do it, but you eventually will set an SES light and your engine won't run very well. You will need a simulator to replace your 02 sensor if you continue to run that way. That said, as 93lt pointed out it is wholly illegal. If caught you run the risk of up to a 10,000 fine. Also it will immediately fail at inspection. Also you may fail emissions. (If you even look like you have a modded truck, a lot of state troopers will examine the truck just for giggles)... Just a word of warning.
Old 01-03-2006, 08:28 AM
metallica21156's Avatar
metallica21156 metallica21156 is offline
just put a catco in. i had a friend of mine cut mine out and weld in a new one. i got a brand new catco 2.5" for $50 off ebay. exhaust sounds real mean now and is louder. sounds more like a V8. not much diff in performance but i'll post if theres a diff in mpg. getting the old cat out is a pain in the but though. ur have to pound it out if you don't drop the torsion bar mounts. we pounded mine out with not 2 much of a problem. new ones been on for 2 weeks and exhaust smells clean and no o2 trips.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 01-03-2006, 03:11 PM
Slap-Bassist531 Slap-Bassist531 is offline
I took out the catalytic converter in my Cougar.... In Tennessee here, I haven't had any problems, been pulled over 2 times since its been done as well (though for speeding), I didn't really notice much in performance or in the MPG but it sure does make it sound loud and mean..... Well, hopefully this was of some help, Have fun bro.
Old 01-04-2006, 09:01 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
police staked out at emissions stations; never seen that before (but not a bad idea, emissions becomes an anti-rice station). if the cat is pulled, it may pass emissions but not a state inspection.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 01-04-2006, 09:15 AM
biv343 biv343 is offline
I replaced my converter this past weekend - got a direct bolt in replacement from Summit - didn't want to mess around with welding one in (since I don't have a good welder). Pain to get out, at least the top bolt on the front. I was able to wedge a cutoff wheel up there to buzz the nut off. Then I had to cut the pipe off the back of the converter to get the old one out. New one slid right in.
