Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 01-03-2006, 07:05 AM
ADK ADK is offline
Brake pedal jumping.
My wife has a 2000 Bravada. When applying the brakes and nearly at a stop, you can feel the brake pedal jump? Any ideas?
Old 01-04-2006, 07:19 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
My 92 has a clunk under similar situations. I determined it was bushungs, mainly the torsion bar bushings. Not a saftey issue. I'm going to put a bushing kit in as soon as it gets warm enough to work in the garage again.
The way to check for bushing noise is to jump on the bumpers and rock the car as hard as you can in park. The noise will probably not be as loud as when you brake, a 2000 lb vehicle coming to a stop at 2g's puts 4000 lbs pressure on the bushings and i only weigh.... oh never mind.
Old 01-09-2006, 03:21 PM
ADK ADK is offline
Re: Brake pedal jumping.
Thanks for your reply, but i,ve edited the original query. What do you think?
Old 01-10-2006, 08:06 PM
ericn1300's Avatar
AF Premium User
Does the jump in the brake pedal only happen when coming to a stop or does it occur when braking hard at speed?
If it happens only when coming to a complete stop it could be the ABS (aniti-lock braking system) not seeing the signal from the brake pedal lamp switch and adjusting pressure after seeing the wheel speed sensor signal a stopped wheel and not knowing you're braking. Check to see if your brake lights come on. Even if they do, replace the switch first. It costs less than $10 and is easy to replace.
they don't have the manual for the '00 yet but the '99 manual will give you a good overview of the ABS system. Link here:
http://www.autozone.com/servlet/UiBr...3d8018cafa.jsp
Old 01-24-2006, 09:49 PM
old_master's Avatar
Advisor/Moderator
One jump of the pedal, just before a complete stop, you can feel it in your foot. More than likely the front caliper bushings are at fault. VERY common problem, this kit should be installed with every brake job. Here is a link to what you need: http://www.partsamerica.com/ProductD...pe=354&ptset=A
(Each kit does one wheel, best to do both sides.)
