Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 01-03-2006, 03:09 AM
Pavlo's Avatar
Pavlo Pavlo is offline
Oil question.
Well this is just general question about oils. Right now I run penzoil high-milage in my civic, I am thinking of switching to Castrol synthetic blend, as I do not want to go full synthetic on my 140k engine.
My question is do I just put the new oil in or do I need to run the cleaning oil?
Thanks
VR6> Anything
FWD sucks for understeer? Swaybars do magic.
Old 01-03-2006, 11:47 PM
Pavlo's Avatar
Re: Oil question.
Bump
VR6> Anything
Old 01-05-2006, 11:41 PM
altimaracer altimaracer is offline
Re: Re: Oil question.
I got tha answer go to the honda section, lol
Old 01-06-2006, 01:48 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: Re: Re: Oil question.
404 Funny Not Found.
I wouldnt bother with synthetic... with 140 on the clock its all just gonna fly by your rings and burn.
I'd think you need to run cleaning oil if you do... The thing is that synthetic oils run alot of solvents so all the deposits are gonna get loosened and run though the filter (possibly also the bearings) so you clean it out before hand. When I switched to Hydrotex the dealer gave me some cleaner to run though for 20minutes...
Old 01-06-2006, 02:32 AM
nissan_240sx nissan_240sx is offline
Re: Oil question.
So if you have high mileage its not good to use synthetic oil? Since I use Castrol synthetic blend in my 160K mile engine. More info on this please.
-Matt
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 01-06-2006, 02:44 AM
Re: Re: Re: Re: Oil question.
-Matt
NISMO
Old 01-07-2006, 09:07 PM
Pavlo's Avatar
-Matt
Pretty much, I've heard of people switching to synthetic with no problems, and there cars that switching to synthetic causes oil to leak out of every hole in the engine (usually higher milage). Thats why I am asking about synthetic blend, as I do not want to go full synthetic.
And wouldn't the cleaner oil make the oil leak as it is really thin?
VR6> Anything
Old 01-11-2006, 01:28 AM
404 funny not found,and the stallowned thing were funny as SH*T so heres some help but you will have to read alot
synthetic oils are also
renowned for their high-temperature thermal stability. Superior
high-temp stability ensures and engine lubricant's capacity to protect
vital engine components during very-high-temperature operation, such as
hot summer driving, sustained high-speed driving, repetitious stop and
go metropolitan driving, driving in mountainous terrain, pulling a
trailer, or any driving with a small harder-working piston or rotary
engine. Underhood temperatures also take a quantum leap with the use of
power options, especially air conditioning, and because of emissions
devices and emissions-related engine redesign. It is important to note
that, even though the dash gauge may register only a 200F or so
water/coolant temperature, the temperature of the sump and of all the
assorted bearing surfaces significantly exceed the water temperature,
and often surpass 500F on the piston ring and cylinder wall areas.These high-temperature surfaces serve to rapidly decompose petroleum oil
and additives, as well as contribute to their shorter service life,
while the synthetic is largely unaffectedTheres more information on this site...http://www.mr2.com/TEXT/synth_oil.txt
Old 01-11-2006, 03:23 AM
Re: Oil question.
Thanks for the info
-Matt
NISMO
Old 01-11-2006, 01:55 PM
R.W.240's Avatar
Banned
You're never gonna get a daily driver civic with no mod hots enough to need synthetic.
If you run High RPM or Turbo you use a 15-40W+ Synthetic... Stock Civic with 160mi on the clock the risks of switching to sythetic out weight the advantages.
Old 01-11-2006, 05:39 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: Re: Re: Re: Re: Oil question.
I think nissanfanatic uses 10w30, seems to work fine for him, I'm not calling you on it, I'm just saying.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 01-12-2006, 08:37 AM
Turbo711 Turbo711 is offline
Re: Oil question.
I switched my old Datsun with 140000 on the clock over to 15w50 and didn't have any problems....till I lost the water pump....
Old 01-12-2006, 04:33 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
Re: Oil question.
i think im using 10-40 right now but i cant remember. I would risk running the full synthetic on an engine that high. Only on low mile engines that are already broken in right would i run FULL synthetic. What kind of oil do you guys use in your trannys (probably GL-4, but what brand?) because the only GL-4 i could find was NAPA brand, but i have also heard of Royal Purple making a GL4 tranny fluid, might have too look into that instead of cheapie napa fluid.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 01-12-2006, 04:36 PM
R.W.240's Avatar
Banned
Re: Re: Re: Re: Re: Re: Oil question.
I use a 15-50 right now and Im about to change to a 15W-40 this next oil change.
What I gather is that higher viscosity oils will break down less with the heat of a turbo Also, the last thing you want on an SR at high RPM is thin oil... thats what will cause you to jump lifters.
Old 01-12-2006, 10:11 PM
Pavlo's Avatar
Re: Oil question.
I did not wanted to switch because I drive it at high rpms, but for the extra protection as synthetic does not break down with time. I think I'll just keep on using Penzoil High Milage until the engine dies, which should be around 400k lol. Don't really want to risk with a perfectly good motor, organic oil + oil change every 3000k = perfectly fine for a daily driver. My conclusion on this.
VR6> Anything
