Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-03-2006, 02:53 AM
rbstang rbstang is offline
SC2 Jerking AGAIN !!
My friends saturn SC2 was jerking then i replaced the spark plugs and air filter then it quit. Now its doing it again. I dont think that its the torque converter actually im praying its not the torque converter. Could it be the wires? how do i know if the wires are dead? any information would be helpful thank you.
Old 01-03-2006, 02:00 PM
Tacuvito Tacuvito is offline
Re: SC2 Jerking AGAIN !!
1. Check your cables, make sure these are making a proper connection at both ends, the coils and the spark plugs.
2. Check your firing sequence. You might want to use a Haines Manual for this project and maybe future ones. You can get one at Autozone for $12.99
3. If after doing the previous two tests it does not improve, Buy new cables. Chances are you might need to replace them. Autozone has the cheapest if you are tight on cash.
Hope this helps. Good luck!
Tacuvito
Old 01-04-2006, 02:22 AM
how much do spark plug wires usually run? money wise.
Old 01-04-2006, 01:53 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
it depends on if you want quality or just run the risk you will have the same problem or wire not last.
QUALITY PARTS
Napa---http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=BEL&PartNumber= 700020&Description=Spark+Plug+Wire+Set+-+Premium
MSD(if ordering from summit just call them, they are not listing sohc and dohc no more. but i do believe these are it)---http://store.summitracing.com/default.asp?target=eadvsearch.asp&SearchType=Make ---you have to enter the thing and search yourself
AC Delco---http://www.partsamerica.com/ProductDetail.aspx?mfrcode=ACD&mfrpartnumber=744QQ &parttype=5004&ptset=A
or check out saturnparts.com
JUNK PARTS
Xact---http://www.partsamerica.com/ProductDetail.aspx?mfrcode=XCT&mfrpartnumber=3148& parttype=5004&ptset=A
Auto Zone wires---http://www.autozone.com/servlet/UiBroker?UseCase=C001&UserAction=performSearch&Par ameters=Auto+Store%7C%7EREGULAR+PARTS+LOOK+UP%7C%7 ESPARK+PLUG+WIRESET
Old 01-09-2006, 08:52 PM
replaced spark plug wires. it has stopped jerking. thanks.
