Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-10-2002, 12:07 AM
reXem reXem is offline
What do I need to take it further?
I have a ZC Engine in my 90 CRX Si. It is turboed currently at 6psi. All I have right now is a FPR and a timing retarder. Next week I am getting a Crane Ignition system with an external coil. I am going to rebuild my engine to a lower compression so I take the psi up to 15ish. Here is a list of what I think I need but I am novice to turbos so please let me know what I am overlooking. Also please let me know of what companies I should look at for these products.
- Pistons
- Rods
- IC - are there any that will just fit a CRX or will it always require custom front end work?
- Injectors
- Fuel Rail
- Fuel Pump
- Programmable ECU (Thinking ZDyne)
- Block Guard (or should I get the block pinned?)
- Do I need a new Crank Shaft?
- How reliable are Manual boost controllers? Should I not bother and save for an electronic one?
- Anything Else?
Old 06-17-2002, 05:38 PM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
Everything sounds good on what you have for plans. No, you wont need a new crankshaft unless you really want one. I havent heard anything bad or good about manual boost controls but i personally think that the electronic ones would be easier to use. What turbo are you running BTW?
95 Integra GS-R
[email protected]
Old 06-17-2002, 06:13 PM
it is from a 88 or 89 Mazda 626
MAZDA 626, MX6 88-92 2.2L IHI RHB52W VJ-11X
Those are the numbers for it...not too sure what they mean though
Old 06-17-2002, 09:36 PM
pvang31019 pvang31019 is offline
there is nothing easier than turning a screw
Old 06-17-2002, 10:47 PM
Sure there is....push a button or turn a knob from inside the car
Old 06-18-2002, 10:12 AM
blackbob's Avatar
blackbob blackbob is offline
Send a message via ICQ to blackbob Send a message via AIM to blackbob Send a message via MSN to blackbob Send a message via Yahoo to blackbob
Well
Me personaly I would go with an electronic boost controller along with a Turbo timmer. Thus you can both control you amount of boost and preserve some life to the turbo !
RogueRacing
"Dare to be different"
SHIFT_imagination
Old 06-18-2002, 11:01 AM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
cranksharft should be ok because they are already forged when out of the factory. for the ECU, i recommend getting Hondata or Haltec. i think the hondata is more affordable like ~$1000. with good tuning on the ECU, you will be able to run boost like never before. also, i HIGHLY recommend getting your fuel injectors at importparts if you haven't already gotten them. they are only $72 bucks there. it's the RC engineering brand.
Old 06-18-2002, 05:29 PM
for the price and function, I love my dual stage turboXS MBC
Old 06-20-2002, 05:19 PM
velocitySiR's Avatar
velocitySiR velocitySiR is offline
Send a message via AIM to velocitySiR
i'd be more worried about rod and bearings before a crank..... stock zc rods aren't anywhere close strong enough to hold 15pounds.
formerly "riceboi" back at ph
1990 Crx Si ..b16a1 ...i/h/e ...PYR Racing head..ctr pistons .. ...flywheel ...stage 2 clutch ...3.5 drop on Ground Controls ...Koni adj's all around ... ...mugen kit ...sloppy yellow paint job ...apex'i vafc ...gsr brakes ...gsr seats ...autometer a/f gauge ...and more crap that nobody cares about
Old 06-22-2002, 09:32 AM
Quetzolcotl's Avatar
Quetzolcotl Quetzolcotl is offline
pistons: wiseco, srp, crower, arias, ect
rods: crower, je, eagle
fuel pump: walbro 255 lph
injectors: get some turbo eclipse injectors 450cc for $50 a set
i'd get the block posted (pinned) instead of a block guard.
intercooler you can use any that will mount under your bumper guard just make sure the piping is on the top or bottom.
"I don't want to sound like a queer or nothin', but I think unicorns kick ass." -Trey Parker from Orgasmo
Be like Ike.
