codes in glovebox
Does anybody know where I could get what all the codes in the glovebox mean? I know I saw it some place, just never bookmarked it.
98 Blazer LS 4x4 (STOCK) ---------------------------------- .ǝɹǝɥʇ noʎ ʇǝb 11ıʍ pɐoɹ ʎuɐ 'buıob ǝɹɐ noʎ ǝɹǝɥʍ ʍouʞ ʇ,uop noʎ ɟı |
Never mind. Found it. Must have had fat fingers when I originally did a search.
Re: codes in glovebox
Here they are, for anyone else that wants them:
http://www.automotiveforums.com/vbul...d.php?t=450285 |
This is handy if you don't want to search through the list. Plus you can cut and paste your actual RPO code descriptions and print them out.
S-10 RPO Codes
Rod 1995 K1500 Ext. Cab Stepside 1997 Olds Bravada AWD 2001 Silverado LT 2500HD CC 4WD 2001 Yukon SLT 4WD |
That's nice, but it doesn't have all the codes. There are a lot of them missing.
I've got two blazers, when I ran the codes, there were two or three codes that it didn't identify and they weren't in the list you provided either.
Go figure.
As a PS, I cross checked the missing codes with two local GM dealer I buy parts from (own a collision repair facility), neither had any idea what the RPO codes were as well.
Which ones were they?
I'll grab my codes and post.
Okay, I'll see if I can find out what they mean and amend the list.
Well, it must have been on my 95 Blazer as the list I printed from the S-10 RPO site is complete.
I'll check the 95 later this evening.
I haven't given up on getting the codes from the 95, to let you know which code(s) wasn't in the list. However, the 1993, all codes were present and accounted for. I also ran a 1997 Olds Bravada last night and all codes were accounted for there as well.
i ran the codes on my 95 a while back and many were not found. the ones not found are as follows;
auo axp c3h day dh2 fe9 qbg rsb ryj slm tfe vxs xbg ybg yd3 yd5 yd6 zbg zq6 zw7 1sl 1sz 6wh 7wh 9ol
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
Not sure what the problem is for you all but here is the list straight from my 95. ZL1power69, as you can see, it brings up all the codes that we have in common for me.
AG1 ADJUSTER FRT ST , "POWER, MULTI-DIRECTIONAL, DRIVER" AJ1 WINDOW TINTED , "DEEP, ALL EXCEPT W/S AND DRS" AM6 SEAT , FRT SPLIT BENCH AP9 NET , CONVENIENCE AU0 "LOCK CONTROL, ENTRY" , REMOTE ENTRY AU3 LOCK CONTROL , "SIDE DR, ELEC" AXP VIN IDENT , "POSITION, MULTI-PURPOSE VEHICLE" A31 WINDOW , "POWER OPERATED, ALL DOORS" A78 ADJUSTER FRT ST BK , "MANUAL, DRIVER & PASS, RECLINING" B30 COVERING FLOOR , CARPET B84 MOLDING B/S , EXTERIOR C25 WIPER SYSTEM , "RR WINDOW, INTERMITTENT" C3H GVW RATING , "5,300 LBS" C60 HVAC SYSTEM , "AIR CONDITIONER FRT, MAN CONTROLS" DAY PLANT CODE , "MORAINE, OH, USA" DC4 MIRROR I/S R/V , "TILT, DUAL READING LAMPS" DH2 MIRROR I/S FRT VAN , "LH & RH, ILLUM, WITH DUAL SUNSHADE" D48 MIRROR O/S , "LH & RH, REMOTE CONTROL, ELECTRIC, COLOR." E55 BODY EQUIPMENT , END GATE FE9 CERTIFICATION , "EMISSION, FEDERAL" FF4 ARM LH , TORS BAR SPRING ADJ (C) FF5 ARM RH , TORS BAR SPRING ADJ (D) GU6 AXLE REAR , 3.42 RATIO JM3 BOOSTER , "BRAKE, 240MM TANDEM, HIGH FLOW" K34 CRUISE CONTROL , "AUTOMATIC, ELECTRONIC" L35 ENGINE , "GAS, 6 CYL, 4.3L, CPI, V6, 90 DEG, HO" M30 TRANSMISSION , "AUTO 4 SPD, HMD, 4L60-E, ELECTRONIC" NF2 EMISSION SYSTEM , "FEDERAL, TIER 1" NP1 TRANSFER CASE , "ELECTRIC SHIFT CONT, TWO SPEED" NP5 STEERING WHEEL , LEATHER WRAPPED N33 STEERING COLUMN , TILT TYPE N40 STEERING , "POWER," N90 WHEEL , 15 QBG TIRE ALL , P235/70R15-102S WOL R/PE ST TL ALS RYJ SHADE , "CARGO AREA, RETRACTABLE" R8T CONTROL , SALES ITEM NO. 69 SLM SALES PROCESSING , STOCK ORDERS UP8 RADIO , "PROVISIONS, AM/FM STEREO, INSTRUMENTATION" U1C RADIO , "AM/FM STEREO, SEEK/SCAN, CD, CLOCK, ETR" U73 ANTENNA , "FIXED, RADIO" U89 WIRING HARNESS , CAR TRAILER VXS VEHICLE , COMPLETE V54 LUGGAGE CARRIER , "ROOF, PAINTED" V73 VEHICLE STATEMENT , USA/CANADA XBG TIRE FRONT , P235/70R15-102S WOL R/PE ST TL ALS X88 MARKET BRAND , CHEVROLET Like I was saying, it's nice a list was provided, but for me, I prefer to type in the codes, then cut and past the list and print them out, pretty fast and easy. Maybe the list was updated since you ran yours.
i used a scanner on s-series.org i believe. may have been the scanner it self. thanks for posting ur list. i'll update mine (have it saved on the computer).
