Old 01-02-2006, 10:49 PM
khalid_20879 khalid_20879 is offline
seafoam
how long should I run seafoam in crankcase before oil change and can I put some in the PCV hole like the can says
Old 01-03-2006, 12:15 AM
OverBoardProject OverBoardProject is offline
Banned
Re: seafoam
Just follow the directions on the bottle.
They're the ones that have done all the research and studies
Old 01-03-2006, 12:50 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
A customer service rep instructed me to put 1/3 in the gas tank, 1/3 in the crankcase, and 1/3 through the PCV valve. I have ran it for about 1500kms(950miles) in the crankcase and it did help, I also had no problems.
Old 01-03-2006, 07:08 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
To sea foam:
Run engine to operating tempreture
Pull hose from brake booster
Have someone hit the gas pedal and maintain around 1000 RPM
SLOWLY pour 1/3 can into brake booster hose. Immediately shut off engine for 1 hour
Pour 1/3 can into crank case (do oil change in about 500 miles)
Pour 1/3 can into gas tank.
When hour is up start truck and go for 3-4 mile drive (do not be concerened if you have a big assed white plume of smoke following you, this is normal)
