Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-02-2006, 09:12 PM
B16Z6+S20's Avatar
B16Z6+S20 B16Z6+S20 is offline
Send a message via MSN to B16Z6+S20 Send a message via Yahoo to B16Z6+S20
Question Ecm
are all OBDI computers compatible with all hondas?? i mean if i have a P28 like in 94 EX civic, will it work in a 94 and up teg? will the vtec engage even if it is an SOHC engine or DOHC? i know that if it works the redline should be the one that the computer has programed on and the vtec engagin at the programed RPM, but will it work?
Old 01-08-2006, 12:01 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Ecm
question should be......................why are you switching ecus? timing and fuel maps are different on all ecus. that is what you need to keep in your mind. will it work..................yes. will the AFRs be be different..............yes.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-09-2006, 06:38 PM
B16Z6+S20's Avatar
Re: Ecm
just curius, cause some guy toldme that i should put a P30 OBDI so the car would run faster, and when i was cheking to see how true this i found that theres an OBDI P72 and mines an OBDII P72.
