Old 01-02-2006, 08:58 PM
curt_h curt_h is offline
now it won't start
1988 honda civic sedan 1.5l throttle body. I have had a high idle issue for awhile now and then this morning I went to start it up and it just cranked and cranked. I have check and it has spark and fuel. It has for the last week or so seemed like it is getting to much fuel and every once in awhile when I start it it acts like it is flooded. I did change the injectors awhile ago and it didn't help. I checked the spark plugs and 3 of the 4 were wet with fuel, I tried to start it with some starting fluid and it still just cranked. Could the timing belt have slipped? the previous owner said the belt was changed so it should have about 30000 miles on it now I looked at it and it seems to be in pretty good shape. Any suggestions on where to start?
Curt
Old 01-03-2006, 07:37 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: now it won't start
Are you sure it has spark? Check for continuity to the coil and ignitor in the distributor.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-04-2006, 06:22 AM
yea I double checked and it has spark. And the timing marks on the cam amd crank pulley are lined up. I took all the plugs out and tried to dry it out as best I could then put the plugs back in and tried to start it on either with the fuel pump turned off. It deffinetly wanted to start but my battery was getting low. Today I'm going to have the injectors cleaned Then I'm not sure which way to go from here.
Old 01-04-2006, 07:40 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
check the distributor, you may have adjusted it to run too lean, which is tilted towards you if i remember right.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
