Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 01-02-2006, 09:51 PM
goforbroke goforbroke is offline
Differential
I have an 89 mazda 2600i and my rear differential broke. (the carrier, spider gears, well i guess everything broke.) I believe that it is a ford 8" rear end but i am not sure. could anybody tell me what it is and if there is a differential that I could use instead of it.
Thanks
Old 01-02-2006, 11:02 PM
Kyrasis6's Avatar
Kyrasis6 Kyrasis6 is offline
Send a message via AIM to Kyrasis6
Re: Differential
It's like a 7 3/4" and its build like a Ford 9" I dont' know of anything that swaps in and the only things I know of to modify it with are from other trucks and involves completly dissassembling the differential and rebuilding it. I've never heard of one breaking unless it has been neglected, even with a V8 swap.
Owner of Mazdatruckin.com
Old 01-16-2006, 11:06 AM
Buck_nked Buck_nked is offline
Re: Differential
If you find a replacement or get something to work let me know!! I looking to change my rear end too.. I just dropped a 350 smallblock in my 86', I'm sure you know, b2000 doesn't have posi. The one wheel peel just isn't cool if you know what I mean!!
Good luck!
Old 01-17-2006, 07:12 PM
Kyrasis6's Avatar
Re: Differential
Don't break it loose to much with that V8 behind it until you get posi or a different rear end. When the differential action kicks in and one tire completly stops and the other tire gets all the power it spinning twice the speed as if both where. Do it to much and you'll blow the rear end.
Old 08-06-2006, 05:27 PM
SomeKlown SomeKlown is offline
Cool Re: Differential
What year rear-ends are compatible with a '91 B2600i 4x4 5spd?
Old 08-07-2006, 07:09 AM
hocbj23 hocbj23 is offline
Re: Differential
89,90,91,92,93 Mazda B2600i rears for 4x4"s.I dont believe there is anything else that works with out some modification.BJ
