Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 01-02-2006, 08:26 PM
m084307 m084307 is offline
95 trooper V6 starter bolts
When laying under the trooper I see the starter motor and only one bolt that's easy to get at. I assume the other is on the other part of the mounting flange (2 bolts), but I can't see a thing. I removed the drivers side tire thinking it would give me a better view but nada. I guess I can't post a photo here to show you, correct?
Old 02-11-2006, 11:18 PM
kdkool kdkool is offline
Re: 95 trooper V6 starter bolts
I just did mines last week. There were some plastic tubing that you gotta push out of the way to see the bolt. Taking out the tire will do u no good. Just go under there w/ a flashlight and a move around things to see where it is. Theres only 2 screws holding the starter down btw. The bar at the bottom makes it kind of hard to reach the screw but with an extension u should be fine. The bolts themselves are 14mm. Good luck!
