Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-02-2006, 07:20 PM
ROBERT S. KAPS ROBERT S. KAPS is offline
Left Fender Almost On Tire
I Started To Feel A Vibration In The Front End And It Went From Bad To Worse Real Quick , I Pulled Over And Looked And I Noticed That The Fender On The Passengers Side Was Almost On The Tire ... And When I Pushed Down On The Pass. Fender It Was Already Down As Far As It Was Going To Go ... The Drivers Side Was Fine ... I Pulled The Strut Off And Inspected It And The Spring Looked Fine ... Could It Be The Spring And I Can'T See Anything Or Could It Be Something Else ? ? ? ? Thanks Bob Kaps P. S . IT'S A 1992 SATURN SL2
Old 01-04-2006, 02:05 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Left Fender Almost On Tire
check for seized parts. inspect balljoints. check ride height.
the only things i can think of in your case are the stock seized in the lowered position, or something in the suspention has broke. i would need to see it myself for a deeper diaginosis.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 01-04-2006, 12:42 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
sounds like a broken or worn spring. if its down on the wheel and it doesnt compress, something is wrong with the spring. if the strut was bad the spring would still hold it up. springs can get weak over time. can you compress the spring pretty easily by hand?
Old 01-04-2006, 04:41 PM
Re: Re: Left Fender Almost On Tire
I DON'T UNDERSTAND WHAT YOU MEAN BY [ STOCK SEIZED ] ??? THERE WAS A LITTLE PLAY WHEN I PUSHED DOWN ON THE FENDER BUT NOT MUCH AT ALL , COMPAIRED TO THE DRIVERS SIDE ABOUT A 2" DIFFERENCE IN HEIGHT OFF THE TIRE ... I TOOK THE STRUT OUT AND I CAN'T SEE A CRACK OR ANYTHING I DIDN'T THINK IT WOULD GET NOR DID I EVER SEE ONE SIDE GET THAT BAD WITHOUT A BROKEN SPRING , MAYBE I JUST CAN'T SEE IT OR IT'S JUST WORN THAT BAD ??? I'M GOING TO CHECK THE BALLJOINT AND LOWER CONTROL ARM BUSHINGS BEFORE I INSTALL THE NEW STRUTS AND SPRINGS ... THANKS BOB KAPS
Old 01-04-2006, 04:46 PM
I HAVEN'T REMOVED THE SPRING OFF THE STRUT AS OF YET BUT STILL ON THE STRUT I CAN COMPRESS IT ABOUT AN INCH OR SO , WHICH I THOUGHT WOULD BE MORE AS I'M 285 POUNDS WITH 18 1/2 ARMS , THATS WHY I POSTED THE THREAD , I THOUGHT THE SPRING WOULD COMPRESS A LOT EASYIER OR I WOULD FIND A CRACK ? ? ? ? BUT I WILL CHECK THE BALL JOINT BEFORE I INSTALL THE NEW ONES THANKS AGAIN BOB KAPS
Old 01-04-2006, 05:09 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Does the lower control arm move freely?
Old 01-05-2006, 03:53 PM
Re: Re: Re: Left Fender Almost On Tire
YES IT DOES AND SO DOES THE LOWER BALL JOINT ...
