Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 01-02-2006, 06:28 PM
mk1966 mk1966 is offline
Deisel sounding motor
I have a 1999 Intrepid with approx. 94k miles. The other day I was driving when I started to hear a clunking noise coming from the motor area. It sounded like I had a desiel motor. It only makes this noise at idle and when the car is at normal operating temperature. When I give it the gas above 1500 rpm the noise goes away. When I let go of the gas the noise is there again. I do not get the noisee when the car is cold. Only at normal operating temperature. I get no check engine or oil pressure light at all. The exhaust is also clean. I am running 10-30 Castrol durablend oil. Any ideas people.
Mark
Old 01-03-2006, 09:22 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Deisel sounding motor
Don't drive it much longer, it sounds like you have a spun rod bearing or possibly piston slap, either way it's very serious and can cause serious engine damage if left unattended. I hate to say this, but you are going to either need a new engine put in or a rebuild.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 01-06-2006, 07:58 PM
Eagle88 Eagle88 is offline
let me guess, a 2.7?
Old 02-25-2006, 08:34 PM
nick bamberger nick bamberger is offline
sometimes an engine in need of a valve alignment will make a similar sound..its more of a pinging at certain RPM, or when under a load.
