Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-02-2006, 05:31 PM
flashmagoo flashmagoo is offline
Angry Not Starting
My 2000 LS V8 isn't starting. I don't have an owner's manual and I'd like to switch out the starter relay with a new one. I just don't know the location. Can someone kindly check thier owner's manual and let me know the location of the relay/s.
Thank you
Old 01-03-2006, 05:30 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Not Starting
I assume you are suspecting the starter relay because your car doesn't crank or click or make any noise when you turn the key to the start position. If that's the case, you may also want to try a different key. Maybe the PATS system is not recognizing your key and disabling the starter relay. Also, make sure your battery cables are clean and tight.
-Rod
