Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
View Poll Results: Anyone blow their engine on Isuzu because of exessive oil use? I want to hear from yo
Blown Engine 1 25.00%
Exessive Oil Use 3 75.00%
Isuzu Notifies, but refused to fix problem 1 25.00%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
Old 01-02-2006, 04:06 PM
Mentalman Mentalman is offline
Isuzu Oil Consumtion
My 2000 Trooper just blew it's engine at only 49,000 miles. I had no problems with it until one day I heard a knocking in my engine. Upon arriving home, I checked the oil, and it was bone dry. I filled up the oil and drove it to work the next day with minor tapping. On the way home, the truck just shut down. When I restarted the truck, it knocked like a rock in a tin can. The local Isuzu dealer says I need a new engine, $7,400. I was in negotiation with the service manager, and he said the best he could do was pay half of the costs. That is not an option since I am finding so many others with the same problem. I am currently in the process of contacting an attorney to file a law suit. If anyone out there is experiencing, or has experienced the same problem, please e-mail me. If there enough of us, this can turn into a class action law suit and Isuzu will be held responsible for replacing all defective ngines in the Troopers and Rodeos. All those out there, please respond. Thanks.
Old 01-02-2006, 06:01 PM
mohawk mohawk is offline
Re: Isuzu Oil Consumtion
Damn! That should not happen!
Did you have an oil consumption issue prior to this incident?
Are you the original owner?
I currently own 2002 with around the same miles. I'm beginning to worry.
BTW...There is another web site you might try...I believe it's PlanetIsuzu or something to that. Edmunds also has a Trooper forum.
Old 01-02-2006, 06:13 PM
Re: Re: Isuzu Oil Consumtion
Mohawk
No oil consumpion problems at all before this. One day my valves were knocking, so when I got home I checked the oil. BONE DRY !!! I filled up, replaced the filter, and thought all was well. I was driving home from work the next day, pulled in to get some gas, and the motor just shut down. After starting the engine, I knew I threw a rod. I had it towed to the garage, and the mechanic told me right away he knew what the problem was. BLOWN MOTOR. He was right. I asked him how he knew. He stated he saw way too many Rodeo's and Trooper's have the same problem (1998-2001). Isuzu will not replace the motor. I say they are going to, because I have found several others with the same problem.
As for your 2002, you shouldn't have any problems. However, I would check your oil frequently, because according to Isuzu, burning 1qt per 1,000 miles is considered "appropriate". Yeah right !!!! I call that a PROBLEM. No fret. I contact my attorney tomorrow. Isuzu will pay, or face several law suits.
Old 01-02-2006, 08:18 PM
pr99trooper pr99trooper is offline
Re: Re: Re: Isuzu Oil Consumtion
Isuzu replaced my short block under warranty. The key was getting them to measure the pistons and cylinder walls. They were out of spec to begin with, and I bet yours are too. (some of the motors were not assembled correctly at the factory). If you download the Trooper Service Manual, it contains all the measurements you need to know and look for with respect to the pistons and cylinder walls. This worked for me.
Good luck.
Patrick
Worst case, the 50/50 deal isn't that bad to fall back on.
Old 01-12-2006, 02:35 PM
The6thFinger The6thFinger is offline
Exclamation I have a 2000 Trooper!
I have 108k miles, and noticed on my last road trip I was burning up oil. I probably added a good 2 quarts over 2k miles.
That is terrible that Isuzu considers that "normal" oil usage. I guess I had better keep a very close watch on my levels!
So for getting those cylinder walls measured for a factory "defect" what would that cost? My engine runs fine BUT i'm almost out of warranty and if I could get a new engine out of the deal I would do it!
Old 01-12-2006, 11:00 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: I have a 2000 Trooper!
I think your only hope fore a new engine is to start the oil monitor program. I hope you have a dealer close ....
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-13-2006, 08:01 PM
Re: Re: I have a 2000 Trooper!
What, may I ask, is an oil monitor program, and how would I get a new motor from this?
Old 01-14-2006, 05:21 AM
rodeo02 rodeo02 is offline
It has to be set up with an isuzu service dept. Basically they change your oil, record the oil level and chart your oil level over a given amount of miles/days. It requires many trips to the dealer. If you wind-up using more than 1qt/1000mi, you have powertrain warranty remaining and you have a good service history, they usually will replace the engine without a fuss. If you have no warranty, unfortunately you are SOL. Legal recourse would cost more than an engine replacement. Isuzu North America is on the endangered species list. There is absolutely no incentive for them to be concerned with keeping happy customers. Your two most cost effective solutions at this point are trade it in as is to the dealer on a less expensive vehicle, or dump $3700 into a new crate engine installation (w/ warranty) and keep it. Hopefully you got a good deal for your 2000 in the first place. Troopers historically have horrific resale value.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-14-2006, 01:57 PM
You have to start an oil consumption test. What this involves is going to your dealer BEFORE your warranty is up and have them change the oil and start a consumption log. I started my test 4 months before my warranty was up, and because it was initiated before, the problem was covered under warranty. After, you will have to return to your dealer at either a predetermined mileage interval or when you need a quart added (which ever comes first). They add the necessary oil to bring the level back to full and record the amount and mileage. They will want to do this 10 times. The only cost that I incurred was the oil changes. The dealer picked up the cost of the oil top ups. My test lasted 7 months with an average consumption of 1 quart per 754 miles. This process weeds out over half of the people that try because of the hassle to get this done. You can't add oil yourself and log it, it needs to be done at the dealer. In my case they required that I have a decarb treatment done ( at my cost), and then one more test done to see if the consumption changed. In my case it made it worse. I had to provide all my oil change receipts to prove that I had changed the oil at the required intervals and with the results of the test, the dealer submitted the results to Isuzu. They dragged their feet for 3 months and did their typical "this and that is missing" but all the required info was there. Ultimately the had the motor taken out at their cost to see what was wrong (like they didn't know). Ultimately they could not deny the results and replaced the motor. From start to finish, it took a year. My costs were the oil changes, decarb treatment, and when they changed the motor I paid for the fluids, and at my discretion a new timing belt, thermostat, plugs and water pump.
Now I travel without a case of oil in the back! Consumption now is 1/8 of a quart in 3000 miles. Normal.
Good luck and I hope you have the patience.
Patrick
Old 03-31-2006, 08:18 PM
Isuzu Guy
interesting post:
http://forum.planetisuzoo.com/viewtopic.php?t=7033
-Ryan
Isuzu Moderator
Car Show Tips
