Old 01-02-2006, 03:50 PM
SComp23 SComp23 is offline
Side View Mirrors
I have a 1998 Blazer, and I am tired of the crappy stock mirrors that always break on the bottom. So after having this happen twice to me now, I decided to upgrade to the 99+ mirrors. The wiring harness does not connect right up on the newer mirrors, so I cut off the harness of my old mirrors to wire up my new ones. Both harnesses have 2 black wires, and then like a purple, yellow, and green wire. Does anyone have any idea what these wires do so that I can properly connect it to my new mirrors?
Old 01-02-2006, 07:49 PM
billibong's Avatar
billibong billibong is offline
Re: Side View Mirrors
Pick up a haynes manual and it has the wiring diagram in it for the outside power mirrors.
Right outside mirror:
Lt Blue and Lt Grn/Blk - ECB
Yellow/Blk - Motor Up/Down Switch
White/Blk - Motor Left/Right Switch
Left OUtside Mirror:
Lt Blue/Lt Grn - ECB
Yellow - - Motor Up/Down Switch
White - Motor Left/Right Switch
ECB connections go to Mirror position switch inside truck.
From the switch in the truck
Like to like on all connections with the exception of the ECb wires that connect to the Light blue from the interior switch.
Black to Ground
Orange to Fuse block courtesy fuse 2 (hot at all times).
Hope this helps.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 01-02-2006, 09:55 PM
Thank you very much! Thats perfect!
Old 01-03-2006, 08:25 AM
billibong's Avatar
Glad I was able to help. You should probably still get a Haynes manual, they are fairly cheap and an invaluable resource.
billibong
Repairs:
Old 01-04-2006, 07:12 PM
Got the mirrors in today and wired them up using my old harness. These mirrors are a HUGE upgrade from the older ones from the 98. These are much more sturdy and do not shake when driving.
Old 01-04-2006, 10:05 PM
Old 01-05-2006, 05:50 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: Side View Mirrors
Did you get the ones with or without the defrosters on them?
Old 01-05-2006, 11:51 AM
I got the ones with the defrosters, because the ones I had previously also had the defrosting feature.
Old 01-14-2006, 12:37 PM
Corey96LS Corey96LS is offline
i was interested in changing the mirrors on my 96 Blazer, and was wondering if i'd be able to put the heated mirrors on or not..
Old 01-14-2006, 01:40 PM
rlith's Avatar
Yes... Just wire it to your rear defroster circuit
Old 01-17-2006, 10:20 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
What would be the easiest way to get to this circuit? Should I use one of those tapping fuses in the fuse blocK? Where are the defroster circuit wires found?
Old 01-18-2006, 05:25 AM
rlith's Avatar
Behind the dash, I forgot the colors off hand, ill have to take a look again. I simply used t-taps.
Old 02-25-2006, 07:23 PM
chcknugget's Avatar
I have a question about the wiring. I did the conversion, but it is not working right.
Up/down works perfectly
left/right works the opposite of the way I'm pushing.
I haven't bothered with defroster yet.
The 99+ mirrors have 5 wires... White, Light Green, Yellow, Black, and another Black. The original harness has 4 wires... White green yellow and light blue.
Right now I have:
white (from switch) connected to white (on mirror)
Yellow (from switch) connected to green (on mirror)
Green (from switch) connected to yellow (on mirror)
Light Blue (from switch) connected to nothing
What's wrong? Rlith help!
Old 02-25-2006, 07:27 PM
Connect the yellow to the yellow, and the green to the green. When I switched up my harness, all of the colors matched up, what year do you have?
Old 02-25-2006, 07:31 PM
chcknugget's Avatar
I have a 96.
When I connected the 3 wires that actually lined up the mirror went whack. It wouldn't go up or down, but diagonal in any directoin it wanted. I think it has something to do with the light blue not being connected...
