Old 01-02-2006, 03:26 PM
steve1979chevy steve1979chevy is offline
Question starting problems
car stopped and when I went to start it again I turned the key and there is just one click. All of the rest of the electical stuff is working fine but the the engine just won't turn over or any thing? Maybe silinoid or starter????
Old 01-02-2006, 03:49 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
Re: starting problems
im experiencing the same exact problem with my 95. i already changed out my starter. let me know if you get it started again, thanks.
Old 01-02-2006, 05:33 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Before you spend a nickel, or rip anything out, Take your battery out of the truck (or car) and take it to your favorite Auto Parts store and have it checked.
Your radio, lights, horn etc. do not require anywhere near the juice it takes to start the engine, hence the clicking.
Test your battery first and eliminate it as the problem.
If the battery tests good, then try the starter. Here is a little trick that I learned with GM starters, Try tapping on the Solenoid with a Tire Iron then immediately turn the key. Sometimes the solenoid gets stuck and the light tap will jar it loose. The key word here is a light tap, a fairly firm but light tap is all that is required. (Your not trying to drive railroad spikes into railroad ties.) If this works, your starter solenoid is on borrowed time, and you will need to replace it.
Old 01-02-2006, 07:09 PM
LTBlazer97 LTBlazer97 is offline
Send a message via AIM to LTBlazer97
Re: Re: starting problems
Yeah good advice, do the above first. Starters aint cheap compared to a battery.
1997 Chevrolet Blazer LT
Black 4x4x4 door
http://www.cardomain.com/ride/665593
Proud Founder of the "Clean, test or replace your MAF sensor club" Im also a member!
