Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-02-2006, 03:09 PM
catfishgeez catfishgeez is offline
transmission fluid change
I have a 99 CV. I was thinking of replacing the automatic trans fluid by using a pump to such up the trans fluid thru the dipstick. Approximately how much fluid can I replace doing it this way vs power flush vs changing filter and some fluid ? Thanks in advance for your replies
Old 01-02-2006, 05:24 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: transmission fluid change
You may get 4 quarts out of the pan. That is an 11 quart + or - a 1/2 quart system. Also if the filter is dirty, you are not helping yourself any.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-02-2006, 07:55 PM
BMFer1's Avatar
BMFer1 BMFer1 is offline
I would recommend using the following steps:
-Drop the pan, clean the pan & magnet, and change the filter. Reinstall the pan, reusing the original reusable gasket.
-Drain the torque converter thru the converter drain plug & reinstall plug
-Remove both tranny cooler lines from the transmission and flush the transmission cooler, preferably with a flush gun & some solvent, or with some "Kooler Klean" aerosol tranny cooler flush. Dry it out thoroughly with compressed air and reattach the lines.
-pour 8 quarts of Mercon V ATF in thru the dipstick tube. Start the car. Pour in 4 more quarts, cycle the shifter thru all positions, then check the fluid. You may need 1 more quart or so.
There is also a slightly different method available at crownvic.net under the tech link, which works fine. The method I outlined is IMHO better though. Either way you go, change the filter and ALL the fluid, or it's a waste of time.
BMFer1
Old 01-02-2006, 09:15 PM
Thanks a bunch..I'll change the filter and flush
