Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-02-2006, 12:02 PM
ashencrumbs ashencrumbs is offline
Send a message via AIM to ashencrumbs Send a message via Yahoo to ashencrumbs
Antenna Motor
Sirs,
I have a 1988 Bonne and the antenna motor, when i connect it to the power, runs continuously and the antenna doesn't move.
I was thinking of spraying it down with PB Blaster( greatest stuff ever made) and seeing if it can manage to loosen things up a bit. But I don't want to damage the electrical components.
Any ideas as to what the problem is?
Thanks,
-A
Old 01-02-2006, 02:10 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Antenna Motor
There is a plastic toothed cable that is conncted to the antenna mast. This cable is drawn through the motor making the antenna go up and down. THey are pretty common to break, or get a tooth or two knocked out, which will cause the antenna to stay put while the motor runs. Some GM antennas have replaceable masts, but there is no part number listed for you car. To fix it, you'll have to replace the entire antenna.
Old 01-02-2006, 10:46 PM
Malachias Malachias is offline
Re: Antenna Motor
Originally Posted by ashencrumbs
Sirs,
Thanks,
-A
Try to contact www.zzperfomance.com
They care about used Bonny parts .
Good luck.
Malachias (Brasil)
Old 01-03-2006, 08:45 PM
Re: Re: Antenna Motor
Good luck.
Malachias (Brasil)
Sorry , I gave you wrong site !...
Try www.schramauto.com ( Pontiac used parts )
Malachias (Brasil)
