Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-02-2006, 11:05 AM
dlistro dlistro is offline
Send a message via AIM to dlistro
Think i am ready to give up
Alright i replaced the fpr, fuel filter and fuel pump and my pressure is now were it should be (about 45psi) so i thought for sure that the car would finally fire up. well i thought wrong. Now it seems to give even less response than before (when it had weak pressure). I dont even get that first few seconds of joy when it starts up and shuts down. NOw there is just nothing. Pretty much just cranks and cranks. I checked all my fuses and also checked the front 4 spark plugs for spark (no blown fuses and plugs all had spark). I have no idea what else to do. My coil packs should be working if i saw spark on the front four plugs right? I dont know. Any other ideas would be helpful before the car goes to the dealer so that they can charge me a million dollars.
Old 01-02-2006, 12:42 PM
maxwedge maxwedge is offline
A990 racer
Re: Think i am ready to give up
Get a noid lite on one injector and see if you have injector pulse and/or spray carb cleaner in the intake see if it fires.
Old 01-02-2006, 05:19 PM
nvmyvettes nvmyvettes is offline
Im not sure about your car ,but I had a car I went through the same thing with.It ended up being my cam sensor.I found out it also controled the fuel.$59.00 my problem was solved.If its not very much and easy to get to, you might want to try it. Good Luck
Old 01-02-2006, 07:55 PM
Re: Re: Think i am ready to give up
do you know if the cam sensor will through out any codes when hooked up to a scanner? (if it is malfunctioning of course) And where exactly is the cam sensor located
Old 01-03-2006, 10:39 AM
Indy8's Avatar
Indy8 Indy8 is offline
Yes it will. Located on the pass side of the rear cylinder head, just rear of the serpentine belt.
Quality isn't expensive, it's priceless.
Old 05-15-2007, 02:02 PM
doming34 doming34 is offline
I was told it could be the timing chains.
Old 05-15-2007, 02:35 PM
A990 racer
Welcome to AF. This thread is way to old to respond to, please look at the dates.
Closed Thread
