Old 01-02-2006, 11:04 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Damnit! Got conned into doing it...
Well, I was given a dash out of a 2001 blazer w/ bezel, cluster, controls (lights, hvac) etc etc for free... So now that it's staring me in the face, I'm gonna have to install it..Passenger side airbag is still good so I'm gonna sell that on ebay and rewire everything...I'll be doing a how-to on this...Probably gonna wait till end of feb to do it..But I have all my 95-97 and 98+ wiring diagrams. Rewiring with pigtails for the cluster looks to be fairly straight forward according to my charts. Will have to weld 2 of the mounting points on the firewall, but with the dash out that will be 10 mins worth of work. So with the passenger airbag not needed, I figure I'm gonna cut a hole in the cover to flush mount my AVIC-88 so it's not in the cargo area anymore.. That will definately be nice... I know, I'm
Old 01-02-2006, 11:16 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Re: Damnit! Got conned into doing it...
Awesome look forward to seeing how it goes.
Old 01-02-2006, 11:28 AM
blazee's Avatar
blazee blazee is offline
Problem?
I'm sure that you'll make it look good. Are you going to keep with the dual colors theme? I really like the way it looks now.
Make sure to take plenty pictures, this would be a great oppurtunity to make a heater core replacement how-to as well. The forum really needs one of those.
Old 01-02-2006, 11:55 AM
rlith's Avatar
Re: Re: Damnit! Got conned into doing it...
New dash is black, there will still be some gray highlights left though. The gauge cluster will be multicolor though
Old 01-02-2006, 01:14 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Wow, that will be quite an undertaking.
Takes a large set of rocks to do something like that when nothing is wrong.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-02-2006, 01:27 PM
OverBoardProject OverBoardProject is offline
Banned
Rlith, Do you think that I could mount a second generation dash in my carburated first generation?
If you think that it would work I'll have to talk to you when your done yours.
Old 01-02-2006, 03:59 PM
rlith's Avatar
You could do it, (its been done) but there is a lot of shaving of the back of the dash you will need to do due to the curvature of the dash
Old 01-02-2006, 04:42 PM
Blazer SS Blazer SS is offline
Don't you just hate it When someone gives you something that will make you work and think!! HA HA. If anyone can do it I know you can. Just let us know how you get around some of the problems that will come up.
Old 01-02-2006, 04:47 PM
rlith's Avatar
Yeah, the only problems I forsee is the cluster wiring, the other wiring is cake. I just have to make sure I don't alter any of the resistance values on the harness and it should be ok. I also know the venting will need to be shifted a little bit as well.
Old 01-02-2006, 05:05 PM
Banned
Re: Re: Re: Damnit! Got conned into doing it...
I'm not too worried about making it fit. More worried about the wiring, and making the insterments all work.
Old 01-02-2006, 05:27 PM
DINO55's Avatar
DINO55 DINO55 is offline
rlith
Son, ya got BALLS. Go for it.......
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 01-02-2006, 07:18 PM
LTBlazer97 LTBlazer97 is offline
Send a message via AIM to LTBlazer97
Originally Posted by DINO55
rlith
You can do it...!
1997 Chevrolet Blazer LT
Black 4x4x4 door
http://www.cardomain.com/ride/665593
Proud Founder of the "Clean, test or replace your MAF sensor club" Im also a member!
Old 01-02-2006, 07:26 PM
billibong's Avatar
billibong billibong is offline
Looking forward to seeing how this one turns out.
Based on your past performance, this should look great. I like the idea of mounting your AVIC-88 in the Air Bags old spot, that should save you some room in the back...
Good Luck, can't wait to see the pics posted.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 01-02-2006, 09:28 PM
rental blazer rental blazer is offline
Re: Re: Re: Re: Damnit! Got conned into doing it...
i know its possable i have seen pic on the net somewhere of a 1st gen carb with a new dash however my qustion is (cuz i used to have a 85 jimmy 2.8) since i took apart my cluster before to get to the bulbs and i can see its a cable driven speedo while the new one is elerontic i can tell cuz of the way the needle moves in my new blazer... my guess is you would have to shave it like he said cuz of the curve other thing is that you problty have to find a adapter of somekind to convert the cable to send elerontic pulse's to the cluster its been done but i assume its ALOT OF WORK,,personlly if it was me i would swap the motor with a bigger one before doing the inside but thats me.....
Old 01-02-2006, 09:43 PM
Banned
Re: Re: Re: Re: Re: Damnit! Got conned into doing it...
Well that's exactly what I'm planing on doing next year. Dropping in a V8 . I've got a low mileage 300hp or so 350 sitting here. And since I'll need a different transmission I may as well get a newer unit with the electronics, and a new wire harness.
If I get a chance to do all this my Blazer will most likely be off the road all summer, and will once again get a complete face lift.
