Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-02-2006, 10:26 AM
ubergoose ubergoose is offline
no spark
93 interga rs: the car was stolen (for the hood and dip stick) and apparently stopped by pulling 2 of the ignition wires.
i get no spark as confirmed by a spark tester/replaced the spark plugs and wires didn't help; engine cranks strong.
i have replaced the igniter & ignition switch wiring, everything else seems to check out, fuses, coil resistance, tdc sensor; got all of the right voltages at the right places. looked at the main relay box but it didn't look like the box opened up. battery was dead when i got the car back so all of the ecu codes are wiped.
called a shop to see if i could get the ecu checked out and was told only while its in the car.
would appreciate any type of suggestions.
thanks.
Old 01-03-2006, 11:23 PM
WReX WReX is offline
Re: no spark
check your crankshaft position sensor
26 PSI anyone?
Old 01-04-2006, 11:35 AM
Re: Re: no spark
WReX-
thanks for the input will check it
Old 01-04-2006, 11:04 PM
Re: no spark
no problem
without that sensor hooked up or wired properly you won't get any spark on cyl. 1 due to no signal but you will still crank, just as you described
26 PSI anyone?
