Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 01-02-2006, 09:53 AM
jayniki jayniki is offline
Thumbs down programming keyless remote
how do you program a 2002 keyless remote
Old 01-02-2006, 11:19 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: programming keyless remote
Make sure that you have all the transmitters you want to be able to use handy because the system will have to "learn" each one, even if they already worked before. *If you have the memory seat/radio/mirror option you'll need to program the remote for 'driver 1' first, then 'driver 2', then up to 2 others. *Here's how to do it:
1. Close the vehicle doors.
2. Turn OFF the ignition.
3. Remove the ignition key from the ignition lock cylinder.
4. Press and hold the driver side door lock switch to the unlock position.
5. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
6. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
7. Insert the ignition key into the ignition lock cylinder. (Do not turn the ignition key in the lock cylinder.) Leave the ignition key in the ignition lock cylinder.
8. Release the door lock switch. The body control module (BCM) will sound three beeps in order to verify the Program Mode has been activated.
9. Press the lock and unlock buttons on the keyless entry transmitter simultaneously for approximately 5 seconds . The BCM will sound two beeps in order to verify that the transmitter has been successfully programmed.
10. Perform the previous step to program up to four transmitters.
11. Remove the ignition key in order to exit the Program Mode.
12. Verify the proper operation of each transmitter.
N.B. Perform steps 5,6 and 7 in fairly rapid succession.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 01-02-2006, 01:26 PM
Question no luck
it didnt work after numerous tries
Old 01-15-2006, 03:48 PM
Onblsht's Avatar
Authorized Vendor
The instructions are correct (same as the Rendezvous. You may want to check the fuses or have the system checked out at your local dealer if you aren't getting a response from the vehicle at all.
Old 08-14-2006, 11:40 AM
shayshebang shayshebang is offline
Very helpful instructions and I was able to do it in less than five minutes. Thanks!
Old 03-19-2007, 05:04 PM
lxpdn lxpdn is offline
I would like to know do you use this same program for a 2003 aztek?
Old 10-20-2007, 08:57 PM
kokomo61 kokomo61 is offline
Should be the same - it's the same for the Grand Prix as well. The only thing that I see missing is pulling the MALL PGM fuse before you start, and putting it back in after it's programmed......
