Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-02-2006, 07:17 AM
nvmyvettes nvmyvettes is offline
not trans Solenoids. Help
Changed solenoids in trany.My Aur still goes from 1st to 2nd,but gets stuck there.I had someone else look at it,they didnt know either however they did say left front wheel bearing was bad.And there was a speed sensor on the bearing.Could this cause the trany to have these symptoms? If not, what would be next on the check list
Old 01-02-2006, 09:50 AM
maxwedge maxwedge is offline
A990 racer
Re: not trans Solenoids. Help
This needs to be put on a full function trans scanner, then the solenoids can be commanded for up shifts and it can be confirmed whether the trans is recieving the proper commands from the pcm, if they are than it is an internal problem, any cel lite here?
Old 01-02-2006, 05:11 PM
yes every time it does it, chk eng lite comes on.But when you turn car off and start it back up its off until you start down the road,then it shifts from 2nd to 3rd, it locks up in 2nd and chk eng lite comes back on.
Old 01-03-2006, 08:50 AM
A990 racer
There will be a history code stored that should give some clue as to what is happening.
Old 01-03-2006, 10:55 AM
baron1701 baron1701 is offline
What Year? 1995 Is The Only One That Will Cost You To Do A Normal Scan for any history codes.
Old 01-17-2006, 06:45 PM
awalkead awalkead is offline
does anyone know how much a dealer would charge to fix these solenoids?
