Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-02-2006, 04:56 AM
Adam_rex Adam_rex is offline
Rough Idle
ok so my 240 went from driving ok to bad... it drives fine for the most part. but when i clutch it or just let it idle it wants to die. not all the time some times it idles fine sometimes it bounces from a 100-1500 rpm idle and other times it just flat out dies. i have put lots of injector cleaner in to see if that was the prob. but nothing. also it is always blowing black smoke. even at idle it smokes like this. so i was thinking its something with o2 or MAF but either one should be pulling up a code.
1993 Nissan 240sx
1992 Nissan 240SX SE
--Parts Car--
1992 Camaro Z28
--blown up--
--getting 350 put in--
1993 Honda civic Del sol
--B16A swap--
--1997 jdm front bumper--
--1997 jdm fenders--
--Upgraded internals--
Old 01-02-2006, 05:59 AM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: Rough Idle
What does "When I clutch it." mean?
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 01-02-2006, 08:36 AM
nissan_240sx nissan_240sx is offline
Re: Rough Idle
I think that means when he pushes the clutch in.
hmm black smoke, hows you're oil? there are alot of factors that come into play for the idle problem.
-MAFS is faulty
-throttle body is sticking/dirty
-fuel filter needs to be changed
-adjusting your tps
-AIV needs to be cleaned
etc. search around, there are many 240 idle threads
good luck
-Matt
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 01-02-2006, 10:33 AM
Chuki_breath Chuki_breath is offline
Re: Rough Idle
yea i was going to say aiv, but i dont know if that would cause smoke. Id replace it all anyways, since %99.9 there bad anyways. Fuel filter is cheap. MAF might be a little more expensive. Throttle body you can look at before you drop cash on. AIV you can do. All that shouldnt be to much cash. Then you shouldnt have to worry about those for a long while.
1993 base model 240sx coupe......to much to list. Just take a look at the link, 10 pages of goods.
http://community.webshots.com/user/nismosilvia240
Old 01-02-2006, 02:16 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: Rough Idle
Black smoke should be something fuel related.
Old 01-02-2006, 07:15 PM
Skylindrftr Skylindrftr is offline
Send a message via AIM to Skylindrftr
Re: Rough Idle
that happened to me when my filter fell off and the maf was pointing at the ground...but I ziptied it to my charge pipe so now its all good...i think its the maf in a lot of cases...check it
Old 01-02-2006, 11:02 PM
driftjunke driftjunke is offline
Send a message via AIM to driftjunke
Re: Rough Idle
How many miles on you motor? Pull your plug, and check them see the condition and you can generally tell whats going on, Ever done a compression test? Might as well while you have the plugs out, just to check the condition of your motor, rings could be getting weak.
E
www.E-EMOTORSPORTS.com
Old 01-03-2006, 02:50 PM
dimitri_ dimitri_ is offline
Re: Rough Idle
What does it do when it's idling and you give it gas?
Do the RPM decrease instead of increase ?
If they decrease check for a leak in the rubber boot connecting the plastic air intake hose, (running accross the radiator), to the throttle body.
it's hard to see in the creases until you remove it and bend it to see in the creases.
Around $80 from the dealer or RTV and duck tape
Old 01-03-2006, 05:10 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: Rough Idle
sounds like you gotta tune it up a little.. check your fuel pump and filter (pump is in-tank and filter is on the passenger side of the engine bay.. to check your pump, go to a quiet place, turn everything off, and turn the key to 'on' and see if you hear the pump), then take your mafs off, clean it and see what happens. for your fuel filter, i'd suggest getting a new one. even a new oem filter will make a huge difference. and they're cheap too. you could also make sure you don't have oil leaks.. pull your plugs and check them.. i don't know what else..
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 01-04-2006, 04:51 AM
Re: Rough Idle
yea i have done most of this when i bought the car. but sounds like i need to do again. and motor has 113k i think when i push gas it runs fine. it only has a prob with idle. and it burns gas. bad. my milage is shit right now. i think its my MAF. but ill look into some of these other things as well.
1993 Nissan 240sx
--Parts Car--
1992 Camaro Z28
--blown up--
--B16A swap--
