Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-02-2006, 01:34 AM
Nocturnall Nocturnall is offline
Send a message via AIM to Nocturnall
Poor Heat
Engine heats up like normal but no hot air comes out of the vents in my 97 explorer. Any ideas?
Old 01-03-2006, 12:58 AM
exploded99 exploded99 is offline
Re: Poor Heat
Drive a couple of miles with the heat turned to max. After shes good and warmed up, feel BOTH heater hoses where they go into the firewall. If both are good and hot, you have coolant making it thru the heater core, and you should have heat.
If they are both good and hot, your fan speeds change like they should, and your a/c comes on when you turn the control knob to the appropriate positions, your controls are probably working ok and you need to research blend door fix / repair for explorers on the net. The blend door actuator breaks, and the door quits moving. About a $1,000.00 for the dealer to pull the dash and fix it, or a few bucks if you are willing to do a little shadetree mechanic work.
Old 01-03-2006, 05:52 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Poor Heat
Good to see ya again exploded99.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-04-2006, 05:14 PM
Re: Re: Poor Heat
Hey, you're still around! I'm still trying to exercise the gray matter a little.
Working on the p.c. - got a trojan. Got a question for you - I'll p.m. you as soon as I get the computer tied down.
Old 01-04-2006, 05:27 PM
Re: Re: Poor Heat
