Old 01-02-2006, 12:18 AM
79Bandit's Avatar
79Bandit 79Bandit is offline
Posi trac rear ends.
on my 79 trans am i have the 3.23 detroit locker and Moroso ring & pinion rear end. And i know its normal to hear it clicking when your turning sharp turns but my questions are number 1 why does it click? and two is it harmfull to the car over time? thanks again
Old 01-02-2006, 01:03 AM
79Bandit's Avatar
Re: Posi trac rear ends.
another question i have is whats the advantage to having both tires going at the same time. traction?
Old 01-02-2006, 05:04 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
i dont know about the clicking..but if its normal, im guessing it cant be too bad.
its better to have both wheels locked because if it can, then when you launch for a drag race you have power to both wheels. what happens is that sometimes one wheel gets more power, or one wheel slips more..and you just get a one-tire-fire. only one wheel burns out, and you go nowhere...
with posi trac you can be sure that both wheels get almost the same amount of power so it launches better.
my posi doesnt click..it just burns out a tire when i make a turn fast...
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 01-02-2006, 10:26 AM
GTP Dad GTP Dad is offline
Pontiac Guy
The stock GM unit uses clutches and springs to lock the wheels together when one begins to spin or loses traction. The detroit locker is a totally different animal. It is a positive locking differential and when it is locked both wheels will turn equally. Most lockers use what look like cogs to lock together. When you go around a turn the cogs release and that is why you are hearing the clicking sound. This is so you don't destroy the locker on sharp turns. It is normal and unless you hear a grinding noise don't worry about the clicking.
Old 01-02-2006, 06:20 PM
importeater38's Avatar
importeater38 importeater38 is offline
Send a message via Yahoo to importeater38
Re: Re: Posi trac rear ends.
man i wish i knew shit like that!
93 trans am hurst shifter and zo6 rims. 94 trans am GT. functional ram air hood w/k&n air box, ROH rims, toyo skins, Borla cat back SS, TB bypass, de-screened MAF, BBK underdrive pully, Mieziere electric water pump, spec stage III clutch. '06 Yukon Denali XL, black, loaded. http://www.cardomain.com/ride/711131
Old 01-02-2006, 07:34 PM
Philo Philo is offline
Re: Re: Re: Posi trac rear ends.
Well, now you do, and so do the rest of us! Isn't this forum great??
