Old 01-01-2006, 11:07 PM
khalid_20879 khalid_20879 is offline
gas in oil
I am smelling gas on my dip stick and truck in running rich, also were is the oil sending sensor on the motor
Old 01-01-2006, 11:23 PM
LTBlazer97 LTBlazer97 is offline
Send a message via AIM to LTBlazer97
Re: gas in oil
Id like to help as best i can but not sure what the specs on the vehicle are, to help yah find your sensor location.
1997 Chevrolet Blazer LT
Black 4x4x4 door
http://www.cardomain.com/ride/665593
Proud Founder of the "Clean, test or replace your MAF sensor club" Im also a member!
Old 01-01-2006, 11:29 PM
Re: gas in oil
If you have the 96- and up 4.3L its on the back of the Block, near the center close to the Distributor.
Not sure for the 94-95 CMFI, maybee someone else has an idea.
Just need a little more info as too any symptoms you may have noticed the last few days...hesitant, bad gas mileage that kinda thing..let us know
Black 4x4x4 door
Old 01-02-2006, 12:13 AM
Re: Re: gas in oil
94 blazer 4.3L CPI VORTEC
Old 01-02-2006, 12:16 AM
Re: gas in oil
very bad gas mileage , On start up fast idle just got the truck 3 weeks ago needs lot of work thank ya for all the help so far
sORRY ABOUT THAT tHE TRUCK IS A 94 4.3L CPI Vortec
Old 01-02-2006, 02:13 AM
DINO55's Avatar
DINO55 DINO55 is offline
Re: gas in oil
khalid_20879
This may be your problem...
http://www.automotiveforums.com/vbul...hlight=4.3+CPI
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 01-02-2006, 02:14 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: gas in oil
gas changes the vascosity of oil, if the two have mixed, the bearings are washed and the moter is, im sorry to say, trashed, time for a full removale and rebuild, hot tank the block and all, or a new moter...
Old 01-02-2006, 05:01 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
I'd have to vote on a bad CPI/Nut kit. You're dumping fuel into the crank case. The big problem with this is that if continue without fixing it, you're going to clean the cylinder walls as well as kill your crank bearings.
