Old 01-01-2006, 11:03 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Interesting smell..........
My blazer has a new smell. its like oil gas and antifreeze all mixed together. not sure what end its from? i think its the front. when i walked around the front to pay for gas it was pretty strong. i figured it was just the gas station natural odor. but then i noticed it later at home. any 1 ever encounter this??
http://jowulf.deviantart.com/
Old 01-01-2006, 11:47 PM
drdd's Avatar
drdd drdd is offline
Re: Interesting smell..........
hmmm ... your radiator also has a small oil cooler inside ... notice the oil lines running into it ? hhhmmmm ... maybe there is an internal leak causing both oil and coolant to mix ??
you got any white smoke from the exhaust?
any overheating or oil pressure problems ?
Old 01-02-2006, 01:04 AM
OverBoardProject OverBoardProject is offline
Banned
Check your PVC valve. And any of the vents on the motor.
My guess is that something popped off.
Or you were driving behind someone loosing lots of fluids spraying them all over your ride for a while.
Old 01-02-2006, 03:21 PM
GirlBear's Avatar
Thanks guys. I'll check that stuff out.
Old 01-02-2006, 07:21 PM
LTBlazer97 LTBlazer97 is offline
Send a message via AIM to LTBlazer97
Re: Re: Interesting smell..........
Im with this guy, also you dont want those mixing. Trust me, just ask my 'ole buicks tranny
1997 Chevrolet Blazer LT
Black 4x4x4 door
http://www.cardomain.com/ride/665593
Proud Founder of the "Clean, test or replace your MAF sensor club" Im also a member!
Old 01-03-2006, 01:46 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
GB , did you find anything today ? Did you smell it at the front or rear ? sweet or pungent ? Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 01-03-2006, 07:03 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
I once came across an interesting smell.. Then I took a bath and it was miraculously gone...
Girlbear, I would start checking your fluids for intermixing.
Old 01-03-2006, 08:18 AM
93LT 93LT is offline
What did you have to eat New Years Eve?
Rod
1995 K1500 Ext. Cab Stepside
1997 Olds Bravada AWD
2001 Silverado LT 2500HD CC 4WD
2001 Yukon SLT 4WD
Old 01-03-2006, 09:10 PM
GirlBear's Avatar
You guys are Sofa King Hilarious!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
Ummmmmm, my little dude is in the Hospital again so I gotta make sure this beast runs propper. Daddy stays with him while Mommy works and commutes back-n-forth, And our truck runs pretty good except for this smell. And on to the smell. it is predominately antifreeze smell now. with the new thermostat its never overheated. When I topped off the system last time. you remember I changed the thermostat recently, i put clean H2O in the overflow. today the overflow is empty? is that ok?
*edit* Bone Dry
Old 01-03-2006, 09:28 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
*edit* Bone Dry
Did you purge the system after you changed the tstat? Hopefully that is the problem. The system if it was really low in coolant will suck in fluid from the overflow. Top it up and see what happens. Other things that will cause the smell can obviously be a leak, either internal or externl leak, seeing you recently did your intake gaskets, make sure all is well in that area. Watch you oil for any signs of contamination.
Old 01-03-2006, 09:30 PM
laxman21's Avatar
laxman21 laxman21 is offline
*edit* Bone Dry
Hmmm...could have taken up room of trapped air in the system. Top it off again and see what happens.
Also, check your oil and tranny fluid for contamination.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 01-04-2006, 01:53 AM
Rmbodie's Avatar
Sorry to hear about the little one being in the hospital again .After the intake manifold gasket change . Did you use a torque wrench with the assembly sequence and retorque after a few miles ? Athough mine is an older model (non-vortec) it called for a retorque . It may have coolant leakage into the intake passages .If you don't see any external fluids leaking , does the exhaust have any detectable white smoke(vapor)after the engine is warm? Q: GB, you have a house hubby? Kool . Rob
2005 Grand Prix.
Old 01-04-2006, 07:12 AM
rlith's Avatar
Drop some of your oil GB to see if any coolant got in there. Also check all your freeze plugs... Check around the manifold and the hoses themselves for any dried grunge matching the color of antifreeze (could be leaking and hiting a hot spot and simply burning up)
Old 01-04-2006, 10:57 AM
GirlBear's Avatar
New Question. How much coolant & water should be in the system? ya know altogether. Oh and no leaks that i can spot, so far. ill check back in soon. might be a few days tho.
Old 01-04-2006, 11:03 AM
GirlBear's Avatar
i want to so bad look at the oil. just have very little time.
