Old 01-01-2006, 10:58 PM
dan3233 dan3233 is offline
Send a message via AIM to dan3233
Question Will a 88 civic 1.6 throttle body work on a 88 civic with 1.5 engine?
Will a 88 civic 1.6 throttle body work on a 88 civic with 1.5 engine? The parts shop said when they looked up the part number for 1.5 the 1.6 came up and said it should work. Just wondering if anyone knew if it would work? Thanks.
Old 01-04-2006, 06:21 PM
Sargento69 Sargento69 is offline
Send a message via MSN to Sargento69
Re: Will a 88 civic 1.6 throttle body work on a 88 civic with 1.5 engine?
it will work but u need to convert the wiring.
°Sä®GëNTö69°
B20B POWERED '91CRX SI
Old 01-05-2006, 12:24 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
a 1.6L MPFI throttle body on a 1.5L DPFI intake mani?? no
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-05-2006, 07:34 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
yeah unfortunately it wont work.. u got dpfi with is dual port which means u only got 2 injectors and well ur engine wire harness and ecu was made for 2 fuel injectors. this is whats all involved for that to happen http://hondacrx881.tripod.com/mpfiswap.html
Old 01-19-2006, 06:07 PM
I replaced the throttle body with a 1.5. Which is the proper one. Now when I start the engine the car revs up then down and almost stalls, it does this about 8 times then the check engine light comes on and it smooths out. I am also getting a code 5 which indicates a map sensor problem. Any suggestions on what could be causing this? Did I hook up a hose wrong to the throttle body? I have never had a map sensor code until today when I put on the new throttle body.
