Heater always blowing hot air
Heater works very well except when you turn it off, both the front and the rear controls. When off hot air still comes out of dash and floor vents.
Also, does any company offer a repair manual for the 01' yukon xl |
Heater always hot
I guess I should have put in my post that its a 2001 Yukon XL SLT, 5.3, power everything.
Re: Heater always hot
Turn your temp down to 60 and turn off. I assume you have the auto HVAC since it's a SLT. The HVAC is still circulating HOT water thru heater core if it's on like 90 even when off.
just a thought Tim |
Re: Heater always blowing hot air
Are you moving when this is happening?
If you are and your vents are open and your temp is at 90, then yes, hot air will sill come out of the vents. If you have it set so that the air comes out of the the floor and the defroster vents, you won't be able to close the vents. You have to choose the "face" vents and then choose the circulation button so that the front vents close. You won't feel anymore air coming in if you do that.
BennyBenster |
Re: Re: Heater always hot
Re: Re: Heater always blowing hot air
I Have the same problem, it seems when you drive with your heat on for about a 1/2 hour or more it doesnt shut down or cool down. also my control dial for the blower doesnt work on setting 1. I thought that this could be my problem, that the unit needed to be replaced and maybe this would cure the problem. |
Welcome to the world of gm, all gm pickups and suv's for the last 15-20 years have done this. Unlike most other vechile makers gm doesn't turn off the hot water running through the heater core when the heater is turned off.
So Horse, is there an after market product that can be installed to secure the hot water going to the heater core during the summer? Doesn't this put a heavier load on the A/C or at least doesn't cool as well as it should.
