Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-01-2006, 09:41 AM
dave7958 dave7958 is offline
stumbles on acceleration
I have a 93 Talon non turbo 2.0. I am having a problem when I accelerate it seems to stumble at first and then catches up with itself. It mainly happens on take off. It feels like it is either misfiring or is lacking fuel/air. I changed the o2 sensor, fuel filter, air cleaner, also I replaced the plugs and wires about a year and a half ago. Any suggestions???????
Old 01-01-2006, 09:32 PM
BizzyBone BizzyBone is offline
Re: stumbles on acceleration
I also have a 93 eclipse that kinda like surges at 3 grand or 3 and a hald grand and off take off also i have changed the spark plugs and still dose it
Old 01-04-2006, 07:53 AM
guidorr73 guidorr73 is offline
I just had the same problem on my 92 talon 2.0 nt. What I found was the tube from the air cleaner to the throttle was cracked in one of the ribs. Could not see or hear it until I started moving things around. The air going into the crack was bypassing the mas causing a stumbling at take-off. Hope this helps.
Old 01-04-2006, 11:55 PM
inatalonIXLR8 inatalonIXLR8 is offline
Were the spark plugs gapped properly?
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 01-11-2006, 09:53 PM
WrecklessMM's Avatar
WrecklessMM WrecklessMM is offline
Re: Re: stumbles on acceleration
mine was stumbling if i had the car in 4th on the highway and went to give it gas or put it to the floor it would kinda backfire or stumble i changed the plugs to splitfires and got 8mm wires and it solved the probem runs alot smoother now too
Old 01-20-2006, 12:28 AM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
hmm check your "thremal vacum valve)" or vacum lines also
