Old 01-01-2006, 09:02 AM
ennay ennay is offline
Noisy Engine 3.1 Litre
Lately my 96 Lumina (191,000 kms) is very noisy at all speeds. The noise seems to come from the AC clutch area. Can someone give some ideas?
Old 01-01-2006, 09:54 AM
maxwedge maxwedge is offline
A990 racer
Re: Noisy Engine 3.1 Litre
Bad pulley bearing? Take the belt off and turn the a/c pulley by hand see if you can feel a bad bearing.
Old 01-01-2006, 11:39 PM
1993LUMINATOR 1993LUMINATOR is offline
Send a message via MSN to 1993LUMINATOR
spray some WD-40 man fixer right up, had that problem more then once befor, just WD-40 when running heavy coat workes great
Old 01-02-2006, 09:30 AM
A990 racer
Re: Re: Noisy Engine 3.1 Litre
If it is the a/c pulley bearing in this case, it is a sealed bearing, the wd 40 won't get into it.
Old 01-02-2006, 09:43 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Drop that wd-40 in the trash can.
For all of the good WD-40 does you might as well pee on it.
Not much more than water.
If you want penetrating oil get some good stuff.
If you want lubricant get some good lubrication.
MT
MT
