Old 12-31-2005, 11:39 PM
jsgold jsgold is offline
Pumpkin gasket question
I am going to change the fluid in the pumpkin on my 93 S-10 Blazer (already did front one) but I had a question on the gasket. I have seen people use silicone only and have seen on posts here where gasket was used too. Is it a problem to put some silicone on the cover to help hold the gasket in place or best to use the gasket by itself?
I used to be indecisive, now I am not so sure.
Old 12-31-2005, 11:59 PM
Crasen Crasen is offline
Re: Pumpkin gasket question
I would use a gasket adhesive instead of silicone to hold the gasket in place during installation it will probably hold a lot better and be less messy
Old 01-01-2006, 12:04 AM
OverBoardProject OverBoardProject is offline
Banned
I used high temp gasket goop only on mine, but highly recomend also using a gasket. I don't have any leaks though
Old 01-01-2006, 12:14 PM
tom3 tom3 is offline
I usually put on the gasket and a real thin layer of silicone, really stops leaks and seepage, and this is a part that will not be touched for years.
Old 01-01-2006, 12:38 PM
drdd's Avatar
drdd drdd is offline
is your diff leaking? if not, and you just want to change the fluid, why not just siphon out the old fluid and refill?
Old 01-01-2006, 01:14 PM
Banned
Re: Re: Pumpkin gasket question
That method does work, but leaves a lot of the contaminants in. They all settle on the bottom and I usually like to wipe everything clean from such areas.
Plus it's the best time to inspect everything and make sure that you don't have any wear. And you'll also know then if you have a posi that isn't working. Often a diff fluid change to the right fluid will get a posi working again. I had this last situation with mine.
Old 01-01-2006, 01:58 PM
The reason I am going to change it is that I found I was a little low on the front one, and I did not like how it looked. The truck has 103K on it and I am pretty sure it is original fluid. Not leaking that I can see but just do not want to start any. I was tempted to use my hand pump but I doubt if I can get all of it out of the rear one and if there are any metal particles I want them out. I should have changed it when I bought the truck (64K) but I just did not think about it. Maybe at 150K I will simply pump it out. Thanks for all of your replies.
Old 01-02-2006, 01:16 AM
Banned
If you've got some springs in there you've got posi which requires a different oil, or an additive.
It would sort of look like this
Old 01-02-2006, 01:53 AM
That is good to know, thanks. I assume the front ends are pretty much all the same (80-90W std. gear oil)?
Old 01-02-2006, 06:54 AM
Banned
I believe that the front ends are the same. I wish that they had posi listed as an option as well
