Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-31-2005, 09:51 PM
big dove big dove is offline
Question oil are what
Well I have this 1999 g m c suburban 5.7 v8 350 it has 204000 miles on it an I have had it since 27000 mile on it changed the oil every 3000 miles but now it sound kind of rough I use 5w30 castrol high mile motor oil but the oil looks good but it sound like the lifters or push rods taping lately when its sitting still would a 10w30 oil help thanks for your time an your help
Old 01-01-2006, 02:06 PM
sub006 sub006 is offline
Re: oil are what
Did your oil pressure drop slightly (like 5 lbs) as the noises appeared? Running conventional oil, you are about at the mileage where ring and bore wear begin to show up.
I've been a Castrol guy myself for 40 years. I have had good luck substituting Lucas Oil Supplement for one quart of oil at each oil change, bringing the oil pressure back up and getting perhaps another 100,000 miles.
I ran my '90 sub 350 on 10-30 GTX for a bit over 200,000 before switching to same weight Syntec Blend, then to full Syntec about 50,000 miles later. The Syntec tends to be a bit "thinner" than same weight conventional, so I tried the Lucas. It ran almost like new until I decided to retire/replace the engine at 370,000 for non-lubrication issues.
If you switch to a full synthetic oil you can at least double your drains to 6-7,000 miles so the higher oil price is canceled out plus you only buy half as many filters.
